Mini 2003 wheel Geometry not right !!
Old Apr 7, 2012 | 12:16 PM
spike47's Avatar
spike47
Hi
I have a 2003 Mini Cooper and Today I took the wheels off for the first time to change the Pads and Disc's .
I noticed that the inner rim of the front nearside wheel , is nearly touching the strut , I checked them both and the front offside Inner rim is 10mm from the side of the strut and the front nearside rim is 3mm .
I can not figure out how that can be , the Hub and strut are fixed in place , so whatever you do you can not alter that angle , offcource the , Camber and Castor can be altered and tracking , but none them will effect the angle of strut to Hub .
I am racking my brains here Folks can anyone shed any light on this !! .
just a note I swapped the front wheels around and the gap,of both remain the same .
cheers
spike
Old Apr 14, 2012 | 08:46 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
When is the last time you have done an alignment?
If it has been more than a year or more than 5000 miles then go to an alignment specialty shop and they can check your suspension for any problems. Sometimes your suspension gets bent and off specs.
SosoMINI
Nov 22, 2015 03:17 PM
bc219
Aug 10, 2015 11:22 AM
joelcseymour
Aug 7, 2015 12:43 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
