What did I just break?
Old Mar 22, 2012 | 12:27 AM
works911's Avatar
works911
So its time of the year to change the tires so I jack up my car on the rear passenger side. I hear a crack! then a mountain of black pellets( probably to filter emission idk) falls off the container underneath the car. Anyone know the fix/cost/problem that will follow?
Old Mar 22, 2012 | 05:22 AM
Noir2005's Avatar
Noir2005
Sounds like you broke your charcoal canister. It is used to store the vapors from the fuel tank. You'll most likely set off your check engine light, and will release fuel vapors. Not sure about driveability problems, but I hear some people do depending on the vehicle. Having that canister broke, could store alot of vapors underneath the car, and could become a fire or even a breathing hazard given the situation.
Old Mar 22, 2012 | 07:08 AM
Mike87's Avatar
Mike87
Check the link for the parts you might need.
http://www.realoem.com/bmw/showparts...93&hg=16&fg=10
Good luck,
Mike
Old Mar 22, 2012 | 04:25 PM
works911's Avatar
works911
Thank you guys. Would it be safe to remove it put back the charcoal and glue it back? I'd rather not pay 250$ for a stupid mistake.
Old Mar 23, 2012 | 12:03 AM
Eric_Rowland's Avatar
Eric_Rowland
Probably easy/cheap enough to get one from a wreckers. Certainly no need to buy new.
Old Mar 23, 2012 | 03:09 AM
HRM's Avatar
HRM
Glue sounds fine to me. I am not certain if it is part of the pressure test the car does on the fuel system, so it would have to hold pressure if you wanted to just do it once, or give it a shot and you may have to seal it better if there is a CEL.
Old Mar 23, 2012 | 05:05 AM
yetti96's Avatar
yetti96
Dumb question but did you look to see where you were jacking up on the car?
Old Mar 23, 2012 | 05:15 AM
Noir2005's Avatar
Noir2005
if you really want to glue it, use the two part industrial epoxy that auto parts stores sell, some are fuel resistant, and have a substantial pressure rating, don't use some chincy super glue, it'll just shatter again.
I as well suggest a used unit out of a wrecked car, just make sure it was hit in the front lol.
Old Mar 23, 2012 | 11:12 PM
works911's Avatar
works911
ok thanks all.
Old Mar 27, 2012 | 06:04 PM
apexer's Avatar
apexer
Originally Posted by works911
ok thanks all.
J-B Weld will do the trick. That stuff is amazing.
Old Mar 28, 2012 | 05:42 AM
dw1's Avatar
dw1
JB weld is an excellent product for an amazing number of repairs. Another option is to go to Ebay and scroll thru what is available. You could subsitute a different cannister as long as you can fit the available space. Many are available for much less than $200.
Lex2008
How to
47
Jun 15, 2022 06:18 AM
Doc Pain
Mar 10, 2021 04:50 AM
vulkandino
Oct 31, 2015 08:29 PM
Nicefeet
Sep 27, 2015 11:14 AM
Sep 4, 2015 09:10 AM
