Suspension Mach V Koni Yellows for R56 rears Question
Old Mar 8, 2012 | 11:03 PM
NintenTom's Avatar
NintenTom
Hey guys. So I ordered a set of Koni yellows from Mach V (fastmini.net) for my R56 and I received the wrong fronts (they were for the R53) but i'm assuming the correct rears according to them (also says R53 on the box). I called them and they said there's a set of spacers/washers that will allow me to use the R53 rears on my R56 provided I use these spacers/washers. Anyone know how to install these R53 rears on my R56 rear with these spacers/washers/etc? Also sort of pissed off since I have to wait 2-3 weeks for the R56 fronts to come in since they're backordered. I've provided a picture of them below.
edit: turns out I didn't even have the bushings/washers they mentioned i needed for the install. but Mach V sent me a pic of what they look like below
Old Mar 15, 2012 | 05:37 AM
richardsperry's Avatar
richardsperry
Dude, really?
If you have the adapters, it will be obvious when you remove the rear shock.
yes, it will work.
W0TM8
Dec 19, 2019 07:50 AM
Emnotek
Aug 13, 2015 05:47 PM
mini yellow-haa!
Aug 13, 2015 11:18 AM
jrezzo
Aug 9, 2015 10:32 PM
