Pacific Northwest Washington, Oregon, and Alaska
For Sale: Hotchkis Rear Sway Bar
Old Mar 7, 2012 | 01:29 PM
kbuscio's Avatar
kbuscio
Brand New, without box, never installed/used, paid $295
$200
Located in Seattle
206-683-6345
Application:
02-06 Cooper, Cooper S
07- Cooper, Cooper S
The Competition Rear is a massive 25.5mm, tubular, 4130 chrome moly sway bar weighing in at only 5.5 pounds! Recommended for competition use only, the Competition Rear has three adjustment positions with the softest setting being the more neutral balance. From there, the middle setting will really aid the Mini's medium to long mid-corner speed where there will not be any throttle feathering needed to turn the car. The stiffest setting is most beneficial through very slow, tight corners where without the bar you'd find yourself on and off throttle several times. With the Competition Rear, this type of corner should only be a one throttle application corner with a rear-steer feel. Although handling characteristics may vary depending on your set-up, each position of the Competition Rear is very distinct and useful. Now you have an advantage at the track and auto-cross course! The set comes complete with polyurethane bushings, bushing brackets and 90-degree zerk fittings for easy lubrication
Rate increse over stock.
Please note: 2005 Mini Convertible Unconfirmed. Bar Coming Soon.
Rear: +226%, +294% & +383%
W0TM8
Dec 19, 2019 07:50 AM
pre shrunk
Aug 18, 2015 11:09 AM
Bennyboy
Aug 18, 2015 07:28 AM
nomar116
Aug 10, 2015 11:24 PM
OutMotoring
Aug 6, 2015 09:32 AM
