Changing upper engine mount, what else?
Old Mar 5, 2012 | 03:12 PM
jmoser's Avatar
jmoser
Time to Replace my leaking upper engine mount.on the passenger side.Anything else I should do at the same time?
I am gOing to have my skid plate off, so it's a good the to do anything else. Recently done
Oil/filter change
Transmission oil change
Radiator flush
How many lower engine mounts are there and should they be changed too?
Old Mar 5, 2012 | 03:33 PM
redhotchilipepper's Avatar
redhotchilipepper
Might check your lower motor mount. I noticed while changing my upper that my lower was all cracked when you pushed on the engine with your hands. It's much cheaper and easier to replace versus the upper mount which is a plus . The lower mount is the one directly under the upper mount and it's safe to assume it is shot if your upper one needed replacing.
Old Mar 5, 2012 | 03:42 PM
jmoser's Avatar
jmoser
Perfect, thanks
Toolman
Jan 20, 2016 06:50 AM
silence2-38554
Nov 12, 2015 09:39 AM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
