Belt Tensioner - When to replace???
Old Feb 23, 2012 | 09:14 AM
KC MCS's Avatar
KC MCS
I realized I should have posted this here instead of in hatch talk, so I'm posting here now. Sorry for putting in the wrong bucket...
How do you know when your belt tensioner needs replaced? Is there a visual indicator (i.e., the #1 hole isn't completely visible when the belt is installed, etc...) or some kind of physical test?
I replaced my belt a few weeks ago and the #1 hole is slightly hidden versus being completely visible.
Thanks!
Old Feb 23, 2012 | 09:28 AM
Helix13mini's Avatar
Helix13mini
Thanks!
How much of the hole that you see is an indicator of the condition of the belt, not the tensioner. If your tensioner is failing, you will hear a rattling, grinding, or squeaking from the front of your engine. If you have a very long screwdriver, prybar or metal rod, you can CAREFULLY touch the non moving part of the tensioner (the bracket) and hold your ear up to the other end to listen for bearing grinding. Do this at your own risk, and watch out for moving parts. If so, it's time for a new tensioner.
Old Feb 23, 2012 | 09:38 AM
KC MCS's Avatar
KC MCS
Thanks, I'll try that test. Like I had said, with my new belt (KO060535) I can see almost the entire 1st hole (I have a 15% reduction pulley), and wasn't sure if that would be different based on the condition of the spring in the tensioner. I guess I thought if the spring was getting weak/worn versus being new, that it would impact the visibility of the hole.
Thanks!
Old Apr 9, 2012 | 03:11 PM
CORNERS's Avatar
CORNERS
What about that little shock absorber? How to know when that's worn out? Mine jumps around a lot. I think that wears faster than the bearing.
Old Apr 9, 2012 | 03:47 PM
Helix13mini
If you can see moisture on the black part of the shock, it's leaking oil, and has failed.
sevin
May 2, 2026 06:11 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
