airbag light on 2006 mcs
Old Feb 14, 2012 | 09:55 AM
pimpedout97x's Avatar
pimpedout97x
A buddy of mine just bought an 06 mcs, and the airbag light is on. Here's a pic of under the drivers seat, does anyone know what or where this harness plugs into
Old Feb 14, 2012 | 01:04 PM
blue2turbo's Avatar
blue2turbo
Is it lighting up that its the passangers side as well?
Old Feb 14, 2012 | 01:15 PM
pimpedout97x
Well the seat belt chime was disabled on this car by the prior owner, and since then, the airbag light is on
Old Feb 14, 2012 | 07:12 PM
pimpedout97x
anyone?
Old Mar 1, 2012 | 03:08 PM
Noonzio's Avatar
Noonzio
This could be the plug for the heated seats - and the heated seats that were in it were replaced by the original owner (a cloth for leatherette swap for example). I did this swap in my 2005 MCS and even though I followed all the instructions correctly (disconnecting the battery, etc) the airbag warning light still came on when I plugged everything back in
Old Mar 1, 2012 | 04:18 PM
Bajanmini's Avatar
Bajanmini
If the circuit has been broken the air bag light has to be reset via code reader,while the light is on the system is inactive.I've had to reset mine 4 times.
Old Mar 1, 2012 | 04:25 PM
Noonzio's Avatar
Noonzio
And is it only the dealer than can do these resets - or is it possible to buy a code reader that will do it? I simply hate having to visit my dealer - they ****** something up every time they touch my car!
Old Mar 4, 2012 | 05:38 PM
Mootsdog's Avatar
Mootsdog
Unfortunately you can only get it reset at the dealer. They tried to charge for a full hour. Spoke to the manager and only charged for a 1/2hr to reset it. I removed my amp. Which is under the pass seat. He told me as soon as I unplugged the harnesses. It would set the light on. Even if you undo the battery. Looks like a trip to the dealer is the only way. Talk to the service manager.
Old Mar 4, 2012 | 06:39 PM
rkw's Avatar
rkw
Not true. It triggers only if you turn on the car (ignition in position 1) while the harness is unplugged.
If you unplug it but don't turn on the ignition, it won't trigger the warning (and of course, nor when the battery is disconnected). I researched this before doing work on my car and have taken the seats out several times without an issue.
However, it is true that once an airbag warning is on, it must be reset by the dealer. Many independent BMW and MINI shops also have a reset tool.
Old Mar 4, 2012 | 06:49 PM
Mootsdog's Avatar
Mootsdog
Good to know next time i have do any under seat work.
Thanks rkw!!
Old Mar 5, 2012 | 12:50 AM
rkw's Avatar
rkw
Back to to original question. According to electrical diagrams, if that connector has 3 wires (the other connectors have only 2) and the wire colors are brown, green/violet, and green/white, then it is the seat heater connector.
Teh
Jun 13, 2018 02:59 PM
one73ronin
Aug 19, 2015 12:36 PM
minipopkart
Aug 13, 2015 05:22 AM
quality_sound
Aug 7, 2015 09:36 AM
