Bushing replacement??
Old Feb 12, 2012 | 12:26 PM
Josh Cooper S's Avatar
Josh Cooper S
So I know this has been beat to death. I want to swap in some new bushings in my 02 S. Can I simply buy the bushings that are pre-installed in the bracket with little trouble. What should I do.
Old Feb 12, 2012 | 04:53 PM
Rich.Wolfson's Avatar
Rich.Wolfson
You should buy the bushings preinstalled. Way and others will sell them that way.
Are you planning to do this job yourself? It is anything but a "little trouble" job. And while you're at it you should do the sway bar bushings and ball joints.
Rich
Old Feb 14, 2012 | 03:49 PM
Josh Cooper S
I plan on buying the pre-installed bushings in brackets.
Can I pull the lower bolt first, then the two that are attached to the sway bar. It looks as if this can be done without dropping the subframe?
Old Feb 14, 2012 | 08:37 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
With the powerflex bushings prepressed you just unbolt the subframe and disconnect the steering column bolt, then pry it down, you can get the bolts for the control arm bushing brackets out then and then just pry the bushings off. Sounds easy but will take a little time.
silence2-38554
Nov 12, 2015 09:39 AM
JPMontes3
Aug 23, 2015 01:26 AM
minipopkart
Aug 13, 2015 05:22 AM
O4mcs
Aug 10, 2015 10:22 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
