R50/53 What other stuff did you do when you replaced control arm bushings?
Old Jan 27, 2012 | 04:23 PM
Stanislaus's Avatar
Stanislaus
My car goes into the shop this weekend. While the subframe is dropped, any suggestions as to trouble areas? I know some people check some other bushings for wear at this time. What did you do/find?
Old Jan 27, 2012 | 05:12 PM
GoThingNC's Avatar
GoThingNC
Some mention the sway bar bushings, check the CV's, power steering hoses, oil pan gasket, crank sensor gasket, check tie-rod ends and ball joints.
Old Jan 27, 2012 | 06:17 PM
Braminator's Avatar
Braminator
+1
Old Jan 27, 2012 | 06:47 PM
GoThingNC's Avatar
GoThingNC
Also the radiator hoses, check the cooling fan speeds, replace the belt (if old) check the steering rack boots...
Old Jan 28, 2012 | 07:35 AM
cristo's Avatar
cristo
Alliance Member
Also check the top strut mounts. Forgot to do that and had to change it at the next annual inspection.
Old Jan 28, 2012 | 08:33 AM
blue2turbo's Avatar
blue2turbo
Everything that was mentioned above are definitely good things to check. I will say this, after having to replace the power steering hoses without dropping the subframe, if yours have not been replaced before, I would HIGHLY recommend doing them while the subframe is out as a preventative task. Then obviously sway bar bushings are right there as well as the steering rack bushings. I would change all of these for sure as well.
Then as mentioned above, check everything for signs of wear or failure. If ANY of the boots have holes in them (CV boots, steering rack boots, ball joint boots) then they need to be replaced as well.
Good luck!
Old Jan 28, 2012 | 09:52 AM
Stanislaus's Avatar
Stanislaus
Thanks, all. I know I have a slight PS hose leak at the fill tank (rubber hose end), going to see what the mechanic says about that. I feel like I'm always keeping one eye on the PS pump and one on the Midlands!
I'm also having one CV axle replaced at the same time. I just changed the belt and tensioner and the radiator fluid myself recently(hoses were fine). I hope the ball joints are still good. I'm hoping only to have to replace a few bushings while he's at it, but come what will I'd rather fix it all together than pay for labor to drop the frame again soon.
Old Jan 28, 2012 | 09:56 AM
Stanislaus's Avatar
Stanislaus
Yeah crank sensor problem and probably thermostat gasket leak is going on, but there's only so much I can do at once. Sticking to what's easily accessible with the subframe dropped. Thanks again!
W0TM8
Dec 19, 2019 07:50 AM
Toolman
Jan 20, 2016 06:50 AM
maestro39
Oct 27, 2015 02:38 PM
JPMontes3
Aug 23, 2015 01:26 AM
Minibeagle
Aug 13, 2015 10:00 AM
