Suspension Coilovers
Old Jan 11, 2012 | 03:41 PM
TheSuspensionSource's Avatar
TheSuspensionSource
Coilovers
Since we get a few calls, PMs and emails about ST coilovers I thought I would create a thread with commonly asked questions.
What is the warranty?
5 year warranty
How low can I drop my car?
R50 Models
Lowering front: 0.8"-2.0" / 20-50mm
Lowering rear: 0.8"-2.0" / 20-50mm
Other models
Lowering front: 1.2"-2.2" / 30-55mm
Lowering rear: 1.2"-2.2" / 30-55mm
Does it work on the Clubman?
These will work on 2008 Clubman models only
How do you adjust the height once installed?
You will have to remove your wheels. When adjusting the vehicle height, it is important to make sure that the threads are clean and free of debris. After initial cleaning, move the perch by 10mm downwards, and then clean the area that you desire to adjust the perch (up or down). For the rear you will remove the perch from the vehicle to adjust the height.
Do I have to modify anything to install ST coilovers?
No these are a direct bolt on
Do I need wheel spacers?
In combination with the original wheel and tires, wheel spacers might need to be used. Customers have reported using 5mm spacers.
Can I use these on my daily in the snow?
ST coilovers have a zinc plated strut housing. This helps prevent corrosion from road grim and salt.
Will these rust?
The chances are very slim. Due to the zinc coating it prevents corrosion and maintains durability of the housing.
Are these better than KW coilovers?
STs are equivalent to KW V1s. ST's carry a different warranty and housing. Some KW models offer dampening control when ST coilovers do not. STs come with pre-set dampening by the KW engineers in Germany.
Do you ship to Canada?
Yes we do but free shipping does not apply. We do offer HIGHLY discounted shipping rates.
What is the cost of ST coilovers?
$976 for all four corners
If you have any questions not answered here please let me know.
RIchard Nguyen
Sep 14, 2016 11:43 AM
Keet
Suspension
Aug 30, 2016 03:46 PM
sssevita
Mar 20, 2016 06:24 AM
CooperSharp
Oct 12, 2015 09:21 AM
gnhovis
Sep 28, 2015 10:56 AM
