Suspension Cross coilovers: Spring rate(s)?
Old Jan 4, 2012 | 07:30 PM
Z06C5R's Avatar
Z06C5R
So I keep coming across posts stating that you get a choice of spring rate when you order Cross coilovers, yet every retailer I see selling them for the MINI lists a specific spring rate and doesn't seem to have facility for changing that. I like their product, but I'd ideally like a more balanced front-rear spring rate split, and maybe something a little more compliant for the frost-heave hell that opens up around here in the winter. I know I could always just buy my own springs for them, but they're awful pricey already...
I know there are a lot of other coilover setups out there that come with more street oriented spring rates - but I absolutely must have linear rate springs, and since M7 is apparently not selling coilovers anymore, the Crosses are really the only choice.
Old Jan 4, 2012 | 07:35 PM
bluefox280's Avatar
bluefox280
Why not buy a set of KW variant 2's (V2) and convert them over to a linear spring set-up?
I'm planning on doing the same by March 2012...
Or buy WayMotorWorks spec'ed KW V2's with linear springs and tenders.
- Erik
Old Jan 5, 2012 | 07:01 PM
Z06C5R's Avatar
Z06C5R
Huh, I hadn't considered that - I sorta figured they were all the standard progressive rate junk. Kinda digging the double-adjust V3's w/ TSW spec springs - Anybody know that the front / rear rates are?
Old Jan 5, 2012 | 07:19 PM
andyroo's Avatar
andyroo
The thing is...you can get whatever you want with the TSW KW's. Just call Way and tell him. Most of them are custom from what I can tell.
+1 for KW or AST over Cross. I never liked Cross.
Old Jan 6, 2012 | 06:32 AM
Mindspin311's Avatar
Mindspin311
For a more budget oriented solution, you may want to look into BC Racing w/Swift springs.
Old Jan 6, 2012 | 10:13 AM
bluefox280's Avatar
bluefox280
WayMotorWorks quoted me a set that were 350 lbs/in both front and rear for a JCW Clubman.
Correct; you can do the same!
- Erik
Old Jan 6, 2012 | 07:26 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Give up on the CROSS, they are not available. And if they were I wouldn't buy them until they have a real production set up and can supply replacement parts. Cross went bankrupt and now there is a US Cross, but they don't have anything and been telling us it will be a couple months for almost 2yrs now.
Just get our TSW KW setup they rock.
Old Jan 7, 2012 | 02:30 PM
Z06C5R's Avatar
Z06C5R
Good point. What kind of spring options do you have with the V3's, and maybe KW's in general? Are they all the same, or can we spec a certain rate like andyroo has suggested?
Old Jan 8, 2012 | 05:45 PM
WayMotorWorks
Vendor
We can do the standard KW V3's or we offer our TSW spec V3's. I suggest the TSW spec they were tested by TSW and make an ideal setup. If you need something for straight track use that is really stiff we'll get you a clubsport setup, but the price jumps pretty good.
Old Jan 9, 2012 | 06:03 PM
Z06C5R's Avatar
Z06C5R
The TSW-spec unit looks like it uses 60mm springs front and rear? In other words, it would be fairly easy to swap out the springs for different rates if I wanted to play with it a bit, assuming I stayed within a reasonable range for the dampers?
smdmini
Oct 7, 2019 06:05 AM
Supertractor3
Apr 7, 2017 11:16 AM
atlantaorange
Sep 16, 2015 12:43 PM
Tires, Wheels & Brakes
Sep 9, 2015 11:08 AM
