Rspeed Slime repair kit
Old Feb 20, 2004 | 01:28 PM
F15EWeapon's Avatar
F15EWeapon
I have a question about this product, and thought my post might benefit others of the same mind.
Is the Slime put into the tire before you get a leak, as a preventative measure? Or do you add it once you get the flat. I can't see well with the rest of the kit... is there a device that helps you put air back in the flat tire after you add the slime?
I guess I just need more details. Thanks for a new product to ponder RSpeed!
Old Feb 20, 2004 | 03:14 PM
Bisch's Avatar
Bisch
you remove the valve stem core, then squeeze it in. replace core and inflate.
go here: http://www.slime.com/what.html
I sold the product about ten years ago. It is a pretty cool product, however not to be used in a high-performance tire application.
Old Feb 20, 2004 | 05:04 PM
kenchan's Avatar
kenchan
I guess that really defeats the entire purpose of Rspeed's ad then:
"We have heard again and again how the run-flat tires just do not perform well. Many Cooper and Cooper S owners (like ourselves) just stick with run-flats and pass up on other tire choices out there that would offer incredible performance.
Well now things are about to change... "
my SP9000 r/f perform just fine, btw.
_________________
03MCS IB/Blk: 123, Aerokit, R90 17x7, Anthrasite Int, TK5 16x7, 6CDMP3, etc.
Old Feb 20, 2004 | 09:43 PM
macncheese's Avatar
macncheese
Hmm. Why cant you use it in high performance tires? I understand that squirting a tube of goop into your tire is going to make the tire unbalanced but it should be a fine temporary fix, no? I dont think your tire guy is going to be happy to find all this crap inside your tire when you replace it either....
Cheese
Old Feb 21, 2004 | 06:57 AM
Bisch's Avatar
Bisch
You can put it in your high performance tire if you wish, but don't expect it to ever be balanced again. You will never get the nail hole or whatever puncture ever fixed because this slime is left in the tire (not removable). No tire shop will touch iot.
Old Feb 21, 2004 | 09:31 AM
kenchan's Avatar
kenchan
very interesting. :smile:
I think i'll just use my SP9000's RF's as is.
Tires, Wheels & Brakes
Aug 26, 2015 10:28 AM
Aug 26, 2015 10:13 AM
Aug 19, 2015 12:51 PM
Aug 19, 2015 08:28 AM
Aug 19, 2015 08:27 AM
