R58 No wheel choices with JCW Works kit?
Old Nov 23, 2011 | 04:32 PM
ulrichd's Avatar
ulrichd
How come the Challenge Spoke is now the only choice with the $2K JCW Package on miniusa.com? You used to be able to choose different wheels.
I can opt for the Sport Package with many wheel choices and then select the JCW Package separately as a dealer accessory but that means it won't be installed at the factory, right?
I am confused.
Old Nov 23, 2011 | 08:00 PM
jamesday24's Avatar
jamesday24
Correct as seen in the 2012 Coupe ordering guide.
http://libraryofmotoring.info/pdf/pr...mini-coupe.pdf
Your dealer might be willing to order the wheels you prefer and then swap them for the Challenge Spokes from the JCW Package.
Old Nov 23, 2011 | 08:48 PM
rkw's Avatar
rkw
There is no such thing as a dealer accessory JCW Package. You'd be ordering each item separately a la carte and have the dealer install them. The aerokit in particular will be quite expensive because it will involve painting as well as installation.
Old Nov 24, 2011 | 08:20 AM
ulrichd's Avatar
ulrichd
You can select it in the Packages section or the JCW section. In the JCW section it shows up as a dealer accessory. And you are correct, as such it would not be installed at the factory and would need to be painted.
It would be an expensive way to get different wheels choices.
Dec 23, 2015 10:36 AM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
