R56 what intercooler has the radiused plate edges
Old Nov 21, 2011 | 08:29 AM
JPMM's Avatar
JPMM
I'm looking for an aftermarket IC that has nice radiused plate edges instead of the flat faces ,but can't find any close-up photos comparing the different ones.
Old Nov 21, 2011 | 12:29 PM
Bigprfed22's Avatar
Bigprfed22
helix i believe has semi circ edges... only one i can think of.
Old Nov 21, 2011 | 01:09 PM
richardsperry's Avatar
richardsperry
What difference does it make? They ALL work the same. Helix, Alta, Forge... All of them work.
Old Nov 21, 2011 | 02:03 PM
Achilles honor's Avatar
Achilles honor
Tell me more what your talking about and i can grab a pic for you off my car. or i might have some pics from when i got the intercooler that might help you
Old Nov 21, 2011 | 02:31 PM
JPMM's Avatar
JPMM
All aftermarket ICs use a bar and plate core, if you look at the front you'll see the turbolators and the bars.The air goes through the turbolators and gets stopped by the flat edge of the plates . Thats why the GP IC works good, it has a different type of assembly and the air is routed through better . Its the same way inside. A curve in front of the bar would help the flow of air.
Old Nov 21, 2011 | 02:49 PM
Bigprfed22's Avatar
Bigprfed22
Like i said helix does have semi circ bars. Has less surface area than the alta intercooler though. They all work about the same but i chose the alat unit for the surface area.
Old Nov 21, 2011 | 03:31 PM
Achilles honor
this does barely any good at all but if you look closely they are all semi-circled like big said i checked
sry iphone sucks in the dark
KinetechMW
Jan 22, 2016 09:04 AM
muddflapp
Sep 20, 2015 03:55 PM
Sep 11, 2015 01:15 PM
USA-RET
Sep 8, 2015 01:50 PM
Sep 3, 2015 02:06 PM
