R56 ugly on my MINI
Old Nov 14, 2011 | 03:13 AM
humsg's Avatar
humsg
ugly on my MINI
Actually wut i want to know is wut if i can replace the side part (as i know that part is part of MINI, i mean MINI is made from a whole steel panel right? ) which they can only replace the rear bumper, and fix the place under the rear light not to replace it. sigh
and here's the 6000M...when it was happened...
Old Nov 14, 2011 | 05:14 AM
richardsperry's Avatar
richardsperry
Yep, replace the bumper cover, and they will fis the metal. Should be good as new.
Old Nov 14, 2011 | 05:24 AM
Drobinson1692's Avatar
Drobinson1692
as long as you're getting a new bumper, i think it's JCW AERO time!
Old Nov 14, 2011 | 07:07 AM
Wildcatlost's Avatar
Wildcatlost
[SIZE=3][FONT=Consolas]The dent in the steel doesn't look that bad at all, no sharp edges. See if you can have someone do paintless dent removal, maybe even at a local dealer. It will save a lot of time and the inevitable bad paint blend.[/FONT][/SIZE]
Old Nov 14, 2011 | 07:32 AM
Porthos's Avatar
Porthos
Try popping it. Take a heat gun, iron, or hair dryer and heat it up. Then push. If the paint doesn't crack you should be good unless its not good enough for you. Give it a try also let the insurance company know you got a dent to see what they can do for you.
Dec 23, 2015 10:36 AM
Dashdog
Aug 10, 2015 06:17 AM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
