R56 Tire slipping crazy when breaking and...
Old Nov 13, 2011 | 02:35 AM
dathinker's Avatar
dathinker
I have 2011 Cooper S and noticed that my tire/steering slipping a lot when I break moderately/hard. I also notice a lot of slipping when hitting bumps or unevent roads.
Is this normal? What's causing this?
Old Nov 13, 2011 | 03:17 AM
ellinara's Avatar
ellinara
It could be a lot of things. First of all how miles do you have on the tires. If they are new make sure to work them in so as the rubber reaches optimum grip. Another thing could be if it hasn't rained in your area that the road could be dirty/oily. This is what I notice here in Greece. Another thing is of course the run-flat tires I found significantly more grip non-runflats than runflats (maybe its just me though). As for even surfaces, I to notice that and I believe it to be normal.
Old Nov 13, 2011 | 04:51 AM
richardsperry's Avatar
richardsperry
You really need to think about your question...
You don't give any real useful information. Where do you live and drive? What's the temperature? What size and brand of wheels and tires? Is it the ABS that you think is not working?
Please be more specific.
Old Nov 13, 2011 | 06:28 AM
klricks's Avatar
klricks
Not sure what you mean by slipping but am guessing that you are hearing/feeling the ABS being activated which would be normal.
Also the DSC can activate the ABS to prevent a wheel spin when accelerating in a corner too fast or on wet slippery pavement, paint stripes etc.
Old Nov 13, 2011 | 10:59 AM
walk0080's Avatar
walk0080
Check your tire pressure. Over-inflated run-flat tires may cause this behaviour. Run-flats also have a habit of causing bump steer and tend to skip over bumps when cornering for example. It shouldn't be too extreme though. One of many reasons why my JCW will not have run-flats.
You can always to a test drive with a MINI technician if you think it is warranty related.
Old Nov 13, 2011 | 11:57 AM
Benibiker's Avatar
Benibiker
How do you know it's slipping?
Sep 17, 2015 09:27 AM
SolCalMini
Sep 1, 2015 08:19 AM
robbiedowns22
Aug 25, 2015 12:20 PM
Powershift
Aug 16, 2015 05:14 PM
minipopkart
Aug 13, 2015 05:22 AM
