R56 Replaced thermostat, can't fill with coolant???
Old Nov 11, 2011 | 05:55 PM
kpreese's Avatar
kpreese
I replaced my thermostat and got all of the hoses and wires reconnected. I poured some coolant (already mixed) into the expansion tank to about half full, turned the bleed valve on the t-stat a few times, cranked the car, set the heater to high temp and lowest fan setting but the coolant just stays in the expansion tank.
I must be missing something simple here.
My old t-stat's bleed screw *looked* like it only needed to be loosened a few turns to allow bleeding. Should I literally be taking that bleed screw out? It's hard to get to so that doesn't seem right.
Was it a mistake to partially fill the expansion tank before cranking the car?
Any help would be most appreciated.
Kevin
Old Nov 12, 2011 | 07:56 AM
bluefox280's Avatar
bluefox280
Directions per the Bentley Service Manual:
R56 Coolant System - Filling and Bleeding (without Vacuum Bleeder)
- Before filling radiator:
* swtich ignition ON - do NOT start engine
* set heater temperature control to full warm
* set blower control to low
* set set heater control (if installed) to maximum
- Start engine and run at idle speed for one mintute (coolant reservoir cap open). Adjust coolant level to MAX level, and close cap.
- Run engine until it reaches operating temperature.
- After engine has cooled, recheck coolant level.
- Top up so that coolant level is at MAX.
- If trapped air cannot be bled manually, pressure-bleed system using cooling system vacuum bleeder.
- Erik
Old Nov 12, 2011 | 09:45 AM
Mini-RI's Avatar
Mini-RI
Search this forum - I know I've read several threads talking about this same problem over the last six months or so...I can't that I recall any special solution other than following the steps exactly as written. Good luck!
Cereall
Sep 5, 2019 06:05 PM
durablack
R55 :: Clubman Talk (2008+)
Oct 5, 2015 01:51 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
PSIChocolate
Aug 13, 2015 12:46 PM
kwijmbo
Aug 5, 2015 09:00 PM
