17" Tire sizes that fit Minis
Old Nov 10, 2011 | 12:28 AM
chaswyck's Avatar
chaswyck
Can someone list the 17" tire sizes that will fit an R56 MCS without rubbing or spacers? Thanks
Old Nov 10, 2011 | 03:15 AM
daflake's Avatar
daflake
stock wheels non JCW?
Old Nov 10, 2011 | 05:30 AM
Porthos's Avatar
Porthos
Depends on the offset but, for the most part 205/45/r17 is a safe size.
Old Nov 10, 2011 | 08:24 AM
KochDeutsch's Avatar
KochDeutsch
I run 225/45/17 Hankook R-S3 on stock wheels with no rubbing or spacers. Stock height. YMMV
Old Nov 10, 2011 | 08:30 AM
bluefox280's Avatar
bluefox280
Here's the common ones:
205/40-R17
205/45-R17 (stock R56 size)
215/45-R17
225/45-R17
225/35-R17
- Erik
Old Nov 10, 2011 | 09:45 AM
rjtrout2000's Avatar
rjtrout2000
I have been running 205/40-17 for over a year now and I have nothing but positive experience to report for them. Not to mention they are inexpensive to replace in comparison to the OEM mini size. (Kumho ASX in 205/40-17 @ discount tire for $74 per tire)
Old Nov 10, 2011 | 07:59 PM
daflake's Avatar
daflake
205/45/r17
What I am running...
Old Nov 10, 2011 | 08:23 PM
chaswyck's Avatar
chaswyck
Thank you guys! My car is on its way and IU need to place an order in tirerack.com for non-RF's.
Old Nov 11, 2011 | 05:13 AM
Derepente's Avatar
Derepente
Hi Chaswyck, I am looking and trying to figure out which size of Non RF tire to go to. I also have 17 wheels (Black bullets). I am thinking about the Nitto INVO tire at 225 45 17 and the ContinentalContactExtreme DWS tire at 205 45 17. Just in case, if you have an opinion on these, I'd be interested.
Old Nov 11, 2011 | 05:19 AM
chaswyck's Avatar
chaswyck
Yes, stock wheels, non-JCW.
Old Nov 11, 2011 | 05:36 AM
Derepente's Avatar
Derepente
The two tires I mentioned above are quieter than the ContiPros that were OEM from MINI. The Nitto INVOs are hard to find on the usual online tire ordering sites. The ContinentalContact Extreme DWS ones are easily found.
Old Nov 11, 2011 | 05:42 AM
chaswyck's Avatar
chaswyck
I'm looking at the Continental Extreme Contact DWS also, but I'm also looking at the Hankook Ventus V12 evo K110. I had the Hankooks, which I got from tirerack.com, on a 335i I recently sold and I loved them. When I swapped out the OEM RF's for the Hankooks, it was like a different car - smooth and quiet. The difference was so great that I never took it for granted or got used to it. Every time I drove the car I thought about how much better those tires were. I didn't have them on long enough to get a sense of treadwear, though and that's my only concern. The Hankooks have a UTQG of 280 and the Conti's is 540. Big difference, but the UTQG doesn't always mean much in terms of actual wear. There's a huge difference in price though. Tirerack.com has the Conti's for $468 a set, but the Hankooks are only $376 a set AND there's a special now where they give you an $80 Amex card rebate if you buy the set. That brings the cost of the Hankooks down to just $296 or $74 a tire (versus $117 for the Conti's). That's awfully hard to pass up. You have to add shipping and mounting to both of them, of course, but you save on sales tax. I think I may have just talked myself into the Hankooks again. (These prices are for OEM size 205 45 17. The 215's are a little more.)
Old Nov 11, 2011 | 05:50 PM
daflake's Avatar
daflake
Any of the tire sizes mentioned should for without issue. I had some slight rubbing with mine but it was due to the off set of the OZ Ultralegggeras.
Old Nov 11, 2011 | 08:56 PM
chaswyck's Avatar
chaswyck
Ok, obviously this is not my area of expertise so I can use some help. Why would I want one size over another. I don't intend to lower the car so I assume the 45's would do a better job of closing the fender gap that 35's or 40's right? How about the 205's versus 215's versus the 225's? It seems like the wider 225's might result in more road stuff being thrown up on the side of the car than the other two narrower tires. What about performance and ride characteristics of the various sizes? I' sure all this exists somewhere on here so I apologize in advance for these pretty basic questions.
Old Nov 11, 2011 | 09:11 PM
PatM's Avatar
PatM
It's really the wheels that will cause the rubbing or that will interfere with your calipers. None of the tire sizes listed will really rub on anything. But if the offset and other factors on the wheel are not correct that is what will interfere with the car proper operation.
But a wheel that is stock and non JCW will take any of the listed tires. But I must warn you that as you deviate from the stock size it will change the way the car handles and you may or may not like it.
Personally I went to 215's from 205 on 17 inch wheels on my R56 and I did not like the way the car handled. It wasn't as crisp as the stock size. I have since put those tires on my new Coupe and the car feels fine. So I guess it really depends on the car and the set up I guess.
Anyway that's what my experience tells me.
Old Nov 12, 2011 | 05:52 AM
AAONMS's Avatar
AAONMS
205/40-R17
215/45-R17
225/45-R17
225/35-R17
- Erik
I don’t recall seeing much in the way of selection for 225/35-17 tires.
Wondering where they could be sourced.
As for PatM’s comment that 215’s resulted in less desirable handling than the OEM 205’s, wondering whether or not this is more a function of sidewall stiffness as opposed to tread width.
Were the two sizes the same brand/model?
Old Nov 12, 2011 | 06:25 AM
fused's Avatar
fused
Just put on Pirelli PZero Nero 225/50-R17 I believe they are 98W rated (168 MPH) -- must test LOL
But just getting the run flats off made the car perform way better and this size seems to give the non run flats a nice footprint. Lov em.....
Old Nov 12, 2011 | 07:42 AM
bluefox280's Avatar
bluefox280
There's a couple to be found (at the time of this writing):
* Yokohama S-Drives
* Falken FK-452
Another size to add to the list would be a 235/40-R17; several availabe in that size as well.
- Erik
Old Nov 12, 2011 | 08:17 AM
jorn's Avatar
jorn
I'm having a heck of a time getting TireRack's website to cooperate with me when attempting to select a tire/wheel pair at the 225/45R17 or 225/35R17 sizes. Am I crazy for wanting that on my '11 R57s?
Old Nov 12, 2011 | 08:51 AM
Derepente's Avatar
Derepente
FYI, looking at thread here, I noticed that one person did report having "rubbing" issues with a stock wheel/suspension setup running the 225-45-17 tire size. I don't want that issue. Plus, as I said, TireVan in Northern VA won't even put them on because it's too far from OEM spec. So now, I am thinking I would like slightly more traction and same or slightly greater wheel height. Thus, I am looking for 215-45 tires and the Continental Extreme Contact DWS tires seem to be the tested favorite.
Has anyone noticed difference in speedometer accuracy running 215-45-17 tires?
I was just on TireRack and had to select custom size so that it wouldn't default to the 205-45-17 size. Jorn, your looking at 225 tires...had you run on these "shoes" before? I thought it might cause rubbing inside the wheel well of a stock suspension setup. I like the idea of more tire on the road. I've read that the wider tire might decrease cornering responsiveness...but I don't know from experience. Your thoughts?
Old Nov 13, 2011 | 03:24 PM
loansinpa's Avatar
loansinpa
I just had them put on about a week ago (215/45 Conti's) but haven't speed tested it yet.
I will say there is a BIG difference compared to what was taken off (205/45 Faulken something or others)
Handling in comparison got much worse. Feels like I'm going to roll the car when taking a tight turn or swerve. Someone mentioned about a 'break in period' for the tires on another thread and I'm hoping that's all it is.
Ride is much better. Don't feel nearly the bumps that I used to on the stiffer tires. With the +1 size and deeper tread it softened it up quite a bit.
I don't track it but there is plenty of opportunity around here to drive it like I stole it. I was really hoping to not sacrifice so much handling for the ride quality.
Old Nov 13, 2011 | 03:38 PM
chaswyck's Avatar
chaswyck
I didn't see a single review on tirerack or other sites that mentioned that much of a performance loss. I hope it's a break in issue too because I just ordered the 215/45/17 Conti DWS's yesterday from tirerack. How aggressively were you driving when you felt like you were going to roll?
Old Nov 13, 2011 | 03:49 PM
loansinpa's Avatar
loansinpa
I didn't think very aggressive. Roll might be an excessive term on my part but it is a big difference comparison to what I was used to. Have found that I can't take usual turns as tight or as fast as I used to. Had a scare when I came up and over a little hill and found a driver coming in the other direction over the line into my lane. Did a swerve and didn't have near the control I think I would have had before. Didn't end up in a corn field but it wasn't a reassuring feeling. Did I mention the ride was much better? I'm not knowledgeable enough on the subject to narrow down if the big difference came from tire type or tire size or both (my guess). I just need to learn to slow down I guess....or not.
Old Nov 13, 2011 | 05:58 PM
nhbouncer's Avatar
nhbouncer
I can say I have had good reviews of the DWS from people as I have sold many to Audi, BMW owners over the last couple of years I have had a few people say they felt soft in the sides when running more aggressive with corning. The other problem i find with the DWS is Conti's issues with keeping inventory up with them other than that all around good multi season tire. I just picked up a 2006 Cabrio S w/JCW kit and it has 205/45/17 Conti SSR run flats now I'm going to ditch those and go with a set of General Exclaim UHP in 205/40/17 I have kicking around my store. Biggest reason being I can put them on my car for like $220 so can't complain about that.
Old Nov 14, 2011 | 02:45 AM
Derepente's Avatar
Derepente
The performance might improve with an increase in tire pressure. What PSI are you running the 215-45-17 CEC DWS tires on now?
I saw an earlier post or thread with Psi higher than what's on the door label.
