R50/53 Road Trip - New transmission
Old Oct 27, 2011 | 12:39 PM
deanmosh's Avatar
deanmosh
Going on a trip from L.A. to San francisco in my 06 MCS - manual. about 400 miles one way.
My question is: is it safe to make this trip back and forth on a brand new transmission? (bottomed out on a gnarly speedbump and cracked the casing, had to replace the transmission).
Are there things I should be weary of while driving 80+ mph on a new trans for about 6 hrs?
Thank in advance, all.
Old Oct 27, 2011 | 01:21 PM
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
Youre good, there's no break in period with a transmision. The clutch on the other hand may require a slight break in, just cant do any kind of drag launches for a couple hundred miles.
Old Oct 27, 2011 | 01:30 PM
deanmosh's Avatar
deanmosh
thanks for the quick response ! had the clutch replaced too but have been gentle. as long as a cruise gently, should be fine right? -in regards to the clutch
Old Oct 27, 2011 | 01:31 PM
martinb's Avatar
martinb
Go for it.
After the trip, make sure you switch to a full synthetic lube if you haven't already. And even if you have, it's a good idea to swap out the lube after that initial run-in.
Old Oct 27, 2011 | 01:34 PM
deanmosh's Avatar
deanmosh
will do! thanks guys!
Aug 14, 2015 11:13 AM
Aug 14, 2015 11:11 AM
Aug 13, 2015 12:57 PM
Aug 12, 2015 01:24 PM
