R50/53 Fuel pump issues?
Old Aug 26, 2011 | 05:47 PM
Roz's Avatar
Roz
Fuel pump issues?
My wife came home today and said the MINI was acting up/ stumbling at take off. I went out to drive it, and it's definitely stumbling while accelerating. It idles fine, but if you give it alot of gas it stumbles/hesitates while trying to rev. It was doing the same a couple of weeks ago, and I replaced the fuel filter, but now it's back, and I suspect the fuel pump itself. Any thoughts?
Old Aug 26, 2011 | 09:54 PM
PatM's Avatar
PatM
How about a little more about the Mini. Year, miles and other pertinent data. That would be a start. I'm assuming there are no warning lights? If there are not then I would get it scoped. It could be several things beside the fuel pump. You could be chasing for awhile and wasting money.
Old Aug 27, 2011 | 03:15 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Any CEL's ?
1) Spark - coil, wires, plugs
2) Fuel - injectors, lines, filter, pump, fuel pressure regulator on fuel rail.
3) Bad DME.
First two good areas to start with.
Check the items in #1 - But after that it is a situation that without a code, you could be chasing this down for days and $$$$$ later. Mechanics have devices to measure any pressure losses in the injection system, and could diagnosis this alot quicker and maybe even cheaper for you in the end.
Old Aug 27, 2011 | 08:05 AM
Roz's Avatar
Roz
Sorry, wasn't thinking. '05 Cooper S, manual, 85k. Only mods are a 15% pulley and Borla exhaust. I'm taking it down to get the fuel pressure checked now.
Old Aug 27, 2011 | 11:07 AM
Roz's Avatar
Roz
Fuel pressure tests ok: 53 psi key on, 45 at idle, drops to 42psi when revving it. Any ideas? No one can look at it until Thursday
Old Aug 29, 2011 | 02:29 PM
Roz's Avatar
Roz
Solved it. Decided to check the plugs, two were 3-4 turns loose, so I decided to change them out (they were replaced 20k ago). Runs like a champ now.
09R56
Nov 16, 2022 10:49 AM
HaveATank
Sep 4, 2015 08:04 AM
scottrn
Aug 22, 2015 07:26 PM
Sikness
R57 :: Cabrio Talk (2009+)
Aug 20, 2015 06:00 PM
kpl
Aug 11, 2015 04:52 AM
