R50/53 Xenon lights on a non-xenon equipped car -- direct swap?
Old Aug 24, 2011 | 07:18 AM
Kahnfucious's Avatar
Kahnfucious
Hi All,
Wanted to see if anyone has done this, is there an FAQ of any type or DIY? Is there special wiring involved?
Thanks.
Old Aug 24, 2011 | 08:12 AM
nitrogen76's Avatar
nitrogen76
Well yes and no.
Technically, yes, they can be swapped.
To be legal, your xenons would need leveling sensors and motors, which you won't have. You'll be blinding people as you drive.
EDIT: you'd need to replace the sockets and add ballasts, etc, but you can swap the wiring apparently... but don't do it.
Old Aug 24, 2011 | 08:39 AM
BlwnAway's Avatar
BlwnAway
Need more info, are you swapping Mini HID headlights into a non HID car or you just talking about an HID bulb kit?
Old Aug 24, 2011 | 12:46 PM
Mike S's Avatar
Mike S
I did this the right way, but it was damn expensive. Was done by BMW as a retrofit.
Old Aug 24, 2011 | 03:25 PM
Kahnfucious
I was talking about Mini HID Headlights into a car that was not originally equipped with them -- headlight housing, projectors etc..
I would never condone HID bulbs and ballasts installed in a non-projector car scattering the light all over the place, creating glare and actually hurting your visibility as a driver.
Thanks for info .. sounds like I should just hunt for a MINI that already has this option.
Old Aug 24, 2011 | 08:43 PM
BlwnAway's Avatar
BlwnAway
Honestly don't know if the wiring is the same up to the point of the headlight itself. (I'd be curious to know myself), might also depend on the year of the car.
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
Dec 23, 2015 10:36 AM
PatrikKN
Aug 5, 2015 09:10 PM
