R50/53 Windshield washer fluid no worko...(no forum solutions I found worked)
Old Aug 9, 2011 | 07:43 PM
ryangschultz's Avatar
ryangschultz
So I recently did a rear wiper delete on my 2004 R50, and I think it was after that that my front windshield washer stopped working. When I turn the ****, I can hear the pump running, but nothing comes out.
I've searched the forum and found possible solutions like a kink in the hose or a leaky reservoir, but there is not a kink in the normal problem area and the reservoir doesn't leak. Any other ideas of what the issue could be? I plugged the rear hose real good when i did the rear wiper delete so I know that's not leaking...
Next plan is to take the hood foam off and check underneath I guess?
Old Aug 9, 2011 | 09:08 PM
RTEnthusiast's Avatar
RTEnthusiast
This is going to be more obvious that you might actually think I'm stupid.
I had the same issue last week. I fixed it by refilling the washer fluid reservoir.
Old Aug 10, 2011 | 03:04 AM
ryangschultz
Haha, I already did that like 3 days ago and it's still full. That's what I originally thought the issue was, until I filled it up. Any other ideas?
Old Aug 10, 2011 | 04:42 AM
jasonzr1's Avatar
jasonzr1
My driver side front washer isn't spraying fully... I'm thinking a safety pin to clear it out?
Poss some dirt or debris has clogged it.
Old Aug 10, 2011 | 06:05 PM
ryangschultz
That could be it, but not for me. I'm not even getting pressure to my hose for the front. I took off the firewall today and no pressure at all all the way there. Now I have to take the stinking wheel off and the whole wheel well cover. Yuck. This better work.
Old Aug 10, 2011 | 06:53 PM
ZippyNH's Avatar
ZippyNH
If you hear the pump, but don't get flow in the hose (sprayer model unplugged to eliminate the possibility of a plug there), and there is nose kinks, I bet the pump is bad...
Old Aug 11, 2011 | 09:44 AM
gwman's Avatar
gwman
I have the same problem, none of my jets work front or rear, and I suspect the pump, just haven't gotten around to replacing it yet. I did read somewhere that a guy reported his pump had stripped gears. It's not hard to get to, it's under the passenger wheel plastic. I'll investigate more the next time I rotate tires.
Old Aug 12, 2011 | 02:44 PM
ryangschultz
I just took mine out and I think it's the same deal, the hoses seem clear so I don't think it's clogged. I really don't want to pay for a new pump, ugh.
Old Aug 12, 2011 | 07:13 PM
ryangschultz
Well it turns out there was just a little bit of grime blocking the rubber strainer. All fixed!
Old Sep 4, 2011 | 07:09 PM
202mini's Avatar
202mini
which rubber strainer? how did you get to it, etc?
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
