R50/53 adjusting day time running lights w/ Xenon low beams
Old Aug 7, 2011 | 01:24 PM
Goop's Avatar
Goop
Do the 2 adjusting screws adjust the DTRLs, just the Xenons or both?
Old Aug 7, 2011 | 01:45 PM
ZippyNH's Avatar
ZippyNH
Your drl's are your highbeams in a gen1 mini with xenons...
lowbeams are xenons, highs are halogen bulb run at lower powerfor drl's.
xenon equipped cars have a self adjusting featilure to compensate for car loading....but the basic aiming should be conventional (screws)....meaning the entire assembly is adjusted, changing the aiming of both.
Old Aug 7, 2011 | 01:59 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
There is a long necked stalk style BMW tool which is passed thru the fender well when bonnet is down for adjusting the HD lights while front of the MINI is facing a flat surface.
If you just pop the bonnet with low beams on, you can acess the screw while watching the ceiling of your garage, adjusting can be accomplished same manner w/o the tool.
Old Aug 7, 2011 | 03:24 PM
Goop's Avatar
Goop
So if use the adjusting screws to set the DTRLs, I won't screw up the Xenons. Good to know.
Not like i'm going to be adjusting my headlights every week to justify the expense of nifty cable adjuster tool.
Old Aug 7, 2011 | 04:21 PM
Hound_va's Avatar
Hound_va
Both will change... not sure how much self-adjustment the Xenons have
Dec 23, 2015 10:36 AM
phrza81
Oct 10, 2015 11:37 PM
iamcamkeenan
Aug 10, 2015 03:31 PM
