Clear Coat Warning
Old Jul 4, 2011 | 03:41 PM
Coopercat2's Avatar
Coopercat2
Clear Coat Warning
I wanted to warn folks not to get too close to the finish of your Mini with those power wash nozzles at do it yourself car washes. I was trying to get some dried on bugs off the front of my Mini after a cross country trip, and got quite close. It took the clear coat off a good section of the front end. Very stupid and very upsetting when I realized what I had done.
Old Jul 4, 2011 | 04:31 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Holy cow that was some powerful car washer !
You can use WD40 for those bugs next time. Dab it on with a rag let it stand for a minute then wipe off. Maguires auto polish dabbed on with same method letting it sit will work too, especially for decal glue...
Could be an Auto body shop may just do some sanding and re-spray of clear to fix that...
Old Jul 4, 2011 | 04:36 PM
docv's Avatar
docv
You probably had a chip in the area that you were trying to remove the bug guts which allowed the high pressure water get under the clear and once that happens there is no stopping it, Grey is correct never use high pressure to remove deposits on paint, there are many ways to do that without damaging the paint.
Old Jul 4, 2011 | 05:05 PM
daflake's Avatar
daflake
WD40 does work, but believe it or not some of the best bug removal I have used is a nylon stocking and some sprite.
Sorry to hear about the bumper. Guess it is time for a respray....
Old Jul 4, 2011 | 05:32 PM
-=gRaY rAvEn=-
Moderator
Sprite for bugs....
Coca Cola for rusted bolts.....
What's Root Beer good for
Old Jul 4, 2011 | 05:59 PM
daflake's Avatar
daflake
Floats!
Old Jul 4, 2011 | 06:04 PM
rkw's Avatar
rkw
That isn't normal. I would place more of the blame on a defective paint job. In fact, if the car is still under warranty, I would try to get it covered.
Those self service wash bays with spray wands are the usual way I wash my MINI, and my 2006 R52 has gone through at least a couple of hundred washes without a problem. In my experience, those wands are not industrial high pressure (like pressure washes used for sidewalks) and not so much different from what you might get from a touchless automated wash, or maybe even driving in the rain at 60 mph.
Old Jul 4, 2011 | 06:22 PM
jerseygirl680's Avatar
jerseygirl680
Wow...Thank you for warning everyone! Maybe there was already a little chip or tear and the power washer just blew it open more? I hope you can get it repaired easily.
Old Jul 4, 2011 | 06:44 PM
Coopercat2's Avatar
Coopercat2
I was just a couple of inches away from the paint though at this point. And it did seem very strong. Mini has a warning in the manual you get with your Mini about high pressure hoses so I think they have covered themselves, but it doesn't hurt to try. I've had the car almost 4 years so doubt there is any warranty at this point.
Old Jul 4, 2011 | 10:01 PM
Porthos's Avatar
Porthos
If it is under warranty ya they will cover the paint. Acctually look at your warranty I wouldn't be suprised if it isn't a 6 or 8 year warranty. I know my rust warrant through MINI is 12 years. I have had to use it already.
Old Jul 4, 2011 | 10:04 PM
Coopercat2's Avatar
Coopercat2
Thanks, Porthos. I will.
Old Jul 5, 2011 | 05:03 AM
yetti96's Avatar
yetti96
If they find any sort of sign of a chip or paint damage it will not be a warranty item as they can say the damage caused the clear to loosen up.
Old Jul 5, 2011 | 07:22 AM
daflake's Avatar
daflake
Yeah, that was the reason I didn't recommend taking it to the dealer. If you caught a rock at some point and then used the high pressure sprayer too close, it can rip the clear coat off. It is worth a try I suppose but I wouldn't bet on it being covered.
Old Jul 5, 2011 | 08:40 AM
ZippyNH's Avatar
ZippyNH
A couple of inches.....
I guess that was way too close....
Sucks...but just proves, stand back, and use some elbow grease and/or some bug+tar remover (or wd-40), then water to clean up.
Thanks for the headsup!
Old Jul 5, 2011 | 08:44 AM
ZippyNH's Avatar
ZippyNH
Onetip....bumpers are so easy to remove, you might be able to carry it into a bodyshop and get it fixed for just a bit....save the unmounting/remounting $$$.
A wetsand blend and rattle can of clear coat might work....on a cool day,no dust/pollen....like a garage with a wetted floor.....depends on how high your standards ate for cosmetics...
Old Jul 5, 2011 | 11:16 AM
eaglebeagle's Avatar
eaglebeagle
i did the same thing to mine a month or 2 ago ... not as bad, but still need a paint shop to go at it.
http://twitpic.com/5foa8k
Old Jul 5, 2011 | 11:23 AM
Coopercat2's Avatar
Coopercat2
@eaglebeagle - It makes me feel better that I'm not the only one to experience this. I sent a photo to my service rep but am not really expecting them to cover it since they warn you in the manual to keep a good distance....I read that after the fact though.
Old Jul 5, 2011 | 01:00 PM
Tater Tot's Avatar
Tater Tot
O.k. I'll bite, why would you think of nylon stockings and sprite! Just wondering was the girl still in the stockings? Because this I can completely understand in the heat of the moment. Wait what was this thread supposed to be about, I've gotten off track.
Old Jul 5, 2011 | 01:27 PM
Coopercat2's Avatar
Coopercat2
Too funny!
Old Jul 5, 2011 | 03:08 PM
eaglebeagle
i plan on going in for the sunroof stickage soon, and i'll see what they say about the paint then, I won't fault them if they can't cover it though.
Old Jul 5, 2011 | 05:02 PM
daflake's Avatar
daflake
LOL, I read it someplace else to be honest and it thought I would give it a shot. I pulled the Mrs out of the stockings first... I'm not that kinky.
Old Jul 20, 2011 | 10:28 AM
Coopercat2's Avatar
Coopercat2
Update on Paint Damage
Just an update, especially to EagleBeagle who also had paint damage from a car wash wand, I got an estimate to fix the front bumper from my body shop. $672! It's not just a matter of removing and reapplying the clear coat. So I was quite depressed but the body shop owner said that this type of damage should not occur on original factory paint. He said they use high pressure washers on cars they fix....shouldn't be a problem. I contacted my service rep at Mini and he had me bring the car in when a rep from Mini was there to look at the damage. Bottom line: Mini is going to cover the damage even though my car is 4 years old and is out of original warranty. I can also have the damage fixed at my local body shop which is great because I live over 50 miles from the Mini dealer. So EagleBeagle, you should take your car into your Mini dealer but call or e-mail first so you can come in when a Mini rep is there.
Old Jul 20, 2011 | 11:25 AM
Porthos's Avatar
Porthos
That is awesome but, I would check just in case it might be a warranty on the paint. Just a suggestion see if that is why they are covering or if they are just doing it out of the goodness of their heart.
Old Jul 20, 2011 | 11:37 AM
Coopercat2's Avatar
Coopercat2
I'm not too sure but I'm assuming it's a paint warranty issue. The car's regular warranty expired a year ago. My service rep indicated that basically it was a no brainer as to being covered. They just wanted to make sure that area had never been in an accident and it was original factory paint.
Old Jul 20, 2011 | 01:35 PM
CoolantGuy's Avatar
CoolantGuy
Manual
States clearley in it not to powerwash
