Group Buy: ST Coilovers
Old Jun 30, 2011 | 11:17 AM
TheSuspensionSource's Avatar
TheSuspensionSource
We have had a few members of the forum ask us for a GROUP BUY on ST Suspensions Coilovers. We figured what the hell...so here ya go!
  • 1-9 Kits $976.65
  • 10-15 Kits $CALL OR PM FOR PRICING
  • 16-20 Kits $CALL OR PM FOR PRICING
Now here is the info on the ST Coilovers:
Adjustable Lowering Heights Front: 0.8"-2.0" Rear: 0.8"-2.0" (For the R50)
Adjustable Lowering Heights Front: 1.2"-2.2" Rear: 1.2"-2.2" (For all other models)
Made by KW Suspensions, the leader worldwide for height adjustable coilover system. ST Suspensions belongs to the KW Automotive company which also owns KW Suspensions, Belltech SportTrucks and LSD Doors.
ST Suspensions - Spring Strut Construction
*Excellent all around performance, providing a balance between performance and comfort for everyday use
*High-quality components for long durability
*Use of twin-tube technology, independent reactions from damping inputs minimized chassis vibrations and increase driving dynamics
*Coilovers come with all necessary components, vehicle-specific certificate and installation instructions
Functional principle of twin tube shock absorbers:
With a Twin-Tube shock absorber, the piston works inside of an inner Tube. The space between the inner tube and the casing is used as an equalization chamber. Changes in volume due position of the piston rod change the oil level in the equalization chamber between the outer casing and inner Tube.
Compression phase:
When the car swings downwards in the direction to the road, the piston rod is moved downwards.
The oil displaced by the piston rod is pressed into the equalization chamber between the Tubes via specially designed orifices in the compression valve at the lower end of the inner Tube. The resistance that is created through this valve creates the actual compression forces. Oil underneath the piston
also flows upwards through the piston check valve with low resistance which also influences the damper characteristics.
Rebound phase:
When the car swings upwards, away from the road, the shock absorber is extended. The piston rod
is extending outward from the housing. The rebound phase valve at the lower Tube resists the oil that flows downwards through the holes in the space above the Tube. Therefore the upward motion is slowed down. When the piston rod is pulled out of the case, its volume is balanced out by the oil that flows from the equalization chamber back into the inner tube through the compression check valve.
For ordering please PM,Call or Email us.
RIchard Nguyen
Sep 14, 2016 11:43 AM
sssevita
Mar 20, 2016 06:24 AM
CooperSharp
Oct 12, 2015 09:21 AM
Snotrocket555
Oct 1, 2015 08:59 AM
gnhovis
Sep 28, 2015 10:56 AM
