Oil drain bolt- BMW cross number?
Old Jun 25, 2011 | 08:06 AM
skrzastek's Avatar
skrzastek
I went to do my first oil change on my new to me R53 and the oil pan drain bolt is completely rounded off (this from a 100% dealer serviced car...) The nearest Mini dealer to me is a 200 mile round trip (or I would just go and buy one), but there is a nearby BMW dealership. Is there a BMW oil drain bolt that is the same as the R53's?
Old Jun 25, 2011 | 09:02 AM
cristo's Avatar
cristo
Alliance Member
A quick perusal of realoem.com seems to indicate that BMW likes to use a 12 mm oil pan drain bolt in all the models I looked at,
and the MINI R53 and R50 uses a M14 x 1.5 pitch one (14 mm thread 1.5mm pitch) - it's also 14 mm long from the gasket/flange to the tip,
and the head takes a 1/2 inch socket, not a 13 mm one. Part number is 11137513050.
You can probably find a suitable generic one at an auto supply store. You could use one with a separate gasket rather than
the integral rubber one on the oem bolt if you like.
Some people like the Fumoto ones with a drain valve. ( http://www.fumotousa.com/main.htm ) The F106 model goes on the R50/52/53.
If you're near an Audi (S4) Acura, Honda, or VW (pre 1999) dealer, some of theirs are about the same size
(as they also use the F106 Fumoto plug, along with as a slew of assorted domestic car models).
Old Jun 25, 2011 | 10:08 AM
Capt_bj's Avatar
Capt_bj
yes - the plug is a VERY common size - any auto part store
Old Jun 25, 2011 | 08:04 PM
skrzastek's Avatar
skrzastek
Thanks for the replies, I ended up just going to Autozone and finding a replacement. The size M14x1.5 is spot on if anyone ever needs to know. I eventually got the bolt out of the pan (that was a blast) Time for a frosty one after the longest oil change I have ever done and a special thanks to an unnamed Mini dealer.........
Moral of the story, don't always just the dealer to "do it right"
Old Jun 25, 2011 | 09:09 PM
Eric_Rowland's Avatar
Eric_Rowland
Originally Posted by skrzastek
...Moral of the story, don't always just the dealer to "do it right"
+1
After the second change, found oil on the garage floor and found the plug finger tight.
After the next change, I discovered they had stripped the threads on the (admittedly ****-poor designed - a whopping 2-3 threads of contact) oil temp sensing drain plug.
Old Jun 27, 2011 | 09:50 AM
Burno's Avatar
Burno
+ 1 on the Fumoto valve its a time saver.......works and built perfectly get the one with the nipple and drain oil on side of car instead of under pan with appropriate hose attached to nipple.....
Kimolaoha
Jul 5, 2023 01:04 PM
Laura Redd Casler
Aug 15, 2015 09:32 PM
Aug 12, 2015 01:24 PM
kpl
Aug 11, 2015 04:52 AM
