R50/53 rapid tire ware with in 700 miles
Old Jun 15, 2011 | 07:42 AM
mustgetwet's Avatar
mustgetwet
having a problem with my 03 cooper s. put new tie rod ends and tires on within 2 weeks (approx 500 miles) the front tires were completely done (hey were ballanced and car alligned). when they put it back on the rack it was toed out by just over and inch. they warrented the tires for me and realligned it. after 700 miles on the new tires they are showing toe in ware. they put it on the rack and it was of 1.2 on right and .5 on the left side.
it was alligned with the proper weights in the car and the tie rod ends were tight. i am the only driver of the car and have hit no noteable pot hole or frost heaves.
please, any ideas as to what we might be missing or causing this problem?
-thanks
Old Jun 15, 2011 | 07:48 AM
Dr Obnxs's Avatar
Dr Obnxs
There are only a few contact points...
so, you have the ball joints, the top of the strut (guide bushing), and the control arm bushing. I'd bet on the control arm bushings being shot.
But it's interesting that you didn't have the problem until the work was done... Everything tight there?
Matt
Old Jun 15, 2011 | 01:50 PM
mustgetwet's Avatar
mustgetwet
for the most part the tires i had on it were only 1 season old and they needed to be replaced, but not 700 miles!. usually i get 2 seasons out of w rated tires these were h so i would have expected longer. i the original post i only mentioned from tie rod end replacement as it was more quantifiable, as i easily could have knocked it out of alignment during the winter. now that you mention it thought that is a strong indication the problem existed before the tierod ends were replaced.
would the bushing actually cause it to be toed out then toed in?
-thanks, tom
Old Jun 16, 2011 | 05:24 AM
NH_MCS's Avatar
NH_MCS
Your LCA bushings could be shot. These can cause a change in toe during acceleration and deceleration.
Old Jun 16, 2011 | 07:03 AM
mustgetwet's Avatar
mustgetwet
would that also show up on the rack. that is if they move during acceleration and deceleration would they stay in the "moved" position stationary on the rack?
-thanks, tom
Old Jun 16, 2011 | 07:24 AM
cristo's Avatar
cristo
Alliance Member
If the LCA bushings are shot, you can get inconsistent toe readings depending
on whether the wheel is pushed fore or aft or in between when on the rack.
With the car on the ground, you can usually rock the wheel about 1/4 inch
fore and aft if the LCA bushings are gone, and the toe changes as the
wheel moves fore and aft as well.
Also, check the inner and outer ball joints and the strut mount for play or wear, as Dr. O mentioned previously.
Rgoodwin
Tires, Wheels, & Brakes
Apr 21, 2017 10:56 AM
reverse01134
Jan 16, 2017 06:37 AM
Powershift
Aug 16, 2015 05:14 PM
xpunisherx
Aug 10, 2015 10:50 PM
