Loud interior vent fan
Old Jun 8, 2011 | 12:01 PM
Neufusion's Avatar
Neufusion
My interior fan suddenly started making a LOT of noise. It vibrates so much, I can't hear the engine over it. It is directly related to the fan speed and doesn't matter if A/C is on or heat is on.
Anyone run into this issue before? Any tips?
Old Jun 8, 2011 | 12:20 PM
ZippyNH's Avatar
ZippyNH
Replacing the fan is suposedly pretty involved....
My fan made some squeeling/screaching noises a couple years ago...
My solution was to lube it up....went away.
Hard to reach, but possible.
remove the filter on the passenger side....and I did it 2 ways...with long extention tube on spray lube (like 2-3 times longer than the freeone), and some on a finger....it is hard to get to....I was reaching in up to my sholder, bent like a monkey...but if you feel around you can determine where it needs lube. Hopefully this works for you.
I used mobil 1 spray lube (good stuff, but I think it no longer made, and some lithium grease (thiner stuff from a can, sprayed on a finger, then applyied by hand)....after about 5 or 10 minutes of running the fan, the sound and lingering smell wentaway. Been a couple of years now.....
Colt45Magnus
Aug 27, 2024 05:03 AM
patsum
26
May 29, 2021 06:29 PM
molala
Oct 2, 2015 01:53 PM
Colt45Magnus
Sep 14, 2015 03:12 AM
Ntety
Sep 2, 2015 08:39 PM
