Drivetrain need torque specs
Old May 26, 2011 | 05:50 PM
freeskier's Avatar
freeskier
need torque specs
im putting the head back on my r53 and need head bolt torque specs, in ft lbs if possible. also need oil pan bolt specs. everything is in, im just waiting on numbers
Old May 26, 2011 | 07:02 PM
soccerbummer1104's Avatar
soccerbummer1104
ok ok ok... ill be nice... (goes to bently manual)
Head to engine block
Stage 1: 30ft-lbs
stage 2: rotate 90 degrees.
*working from inside out
tighten in order like this
11:09:05:01:04:08
12:10:06:02:03:07
thats as you look at the head, if the numbers were over the bolts, tighten in order from 1 to 12
Oil Pan: 23 ft lbs
in order
10:06:02:03:07:11:12
09:05:01:04:08:13
the oil drain plug is between bolts 4 and 8
bolts 10, 9, and 12 are on the sides of the pan, and with bolt 13 at the bottom corner on the side of the drain plug.
hope this helps!
motor on!
Old May 27, 2011 | 03:04 AM
cmt52663's Avatar
cmt52663
Stage 1: 30ft-lbs
11:09:05:01:04:08
12:10:06:02:03:07
Oil Pan: 23 ft lbs
in order
09:05:01:04:08:13
hope this helps!
motor on!
What a sweetie! Blessed are those that will dig for others...
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
Willafb
R55 :: Clubman Talk (2008+)
Nov 6, 2015 08:08 PM
Fordgt4
Oct 10, 2015 10:42 AM
MGBill1186
Oct 2, 2015 06:54 AM
gnhovis
Sep 28, 2015 10:56 AM
