Adding 05+ fan shield to 04 R53
Old May 22, 2011 | 12:24 PM
Cavalier Cooper's Avatar
Cavalier Cooper
I'm sure this has been answered before, but I combed through a lot of posts and didn't find the answer, so I appologize in advance for the repost.
I have an 03/04 build date Cooper S. I want to improve the protection of the power steering fan. Mini Mania states that in 04 MINI improved the fan's shroud. Is that for all 04s or was it done mid model year?
I'm thinking about retrofitting the 05+ air duct and want to see if it is necessary with my model's current equpitment-- or if there is a better option available? Also, to retrofit the air duct, I need to also purchase the 05 underbody paneling correct?
RealOEM is a little confusing in terms of parts, everything says "for automatic transmission" Which parts do I need? I'm assuming #2 and #3 with all necessary clips and screws.
http://realoem.com/bmw/showparts.do?...66&hg=51&fg=75
Old May 22, 2011 | 12:56 PM
Eric_Rowland's Avatar
Eric_Rowland
Technically you need the new underbody panel, but I suppose you could just swiss cheese the OEM part. It says A/T only because for whatever reason only the A/T cars got the ducting.
Old May 22, 2011 | 01:03 PM
Cavalier Cooper
Thanks. Do you know MINI's reasoning for not adding the ducting on manual cars? That seems odd, I can't imagine that manuals are any less prone to damage/overheating. The air duct does fit on cars with manual transmissions without need to retrofit anything, correct?
danielbrookes_9
Oct 3, 2015 12:51 PM
theunlimitedone
Aug 31, 2015 08:17 PM
Chippawaguy
Aug 19, 2015 10:59 AM
Emnotek
Aug 13, 2015 05:47 PM
rckrzy1
Aug 11, 2015 06:06 PM
