R50/53 Key with Remote for 05 S
Old May 15, 2011 | 04:38 AM
HuntersRun's Avatar
HuntersRun
I just bought an 05 MCS, it had only one key, but the remote does not work...batteries are dead. Where do you get a new remote without going to BMW and getting screwed? Are there any aftermarket remotes?
Thanks,
Old May 15, 2011 | 05:23 AM
moreorless's Avatar
moreorless
No.
Dealer item only.
Old May 15, 2011 | 05:53 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Batteries are cheap.
My set came with two remote style keys, but most folks have one remote key and one basic mechanical key and then one made of plastic which fits into your wallet which operates door lock and ignition. So having just one remote style key is not uncommon.
Old May 15, 2011 | 06:22 AM
HuntersRun's Avatar
HuntersRun
Batteries are not replaceable. This is a sealed remote..from what I read..it is recharged when in the ignition slot
Has anybody tried to replace the rechargeable battery in the remote?
Old May 15, 2011 | 07:42 AM
-=gRaY rAvEn=-
Moderator
It is trickle charged from what I understand, not a NiCad battery set up perse'.
Takes CR2032 battery MINI part no. 66126912985 - but can be had other places as well.
Remove the ring and there is a place to separate the back at the key's loop.
Old May 15, 2011 | 07:53 AM
mastawyrm's Avatar
mastawyrm
CR2032 is everywhere but it needs a rechargeable? Anyone ever tried just a typical alkaline? If you have an old computer that you never threw away, just take the battery from the motherboard. That should be a CR2032 :P
Old May 15, 2011 | 10:46 AM
ZippyNH's Avatar
ZippyNH
The 05 has a rechargable battery....
It is recharged when in the ignation....inductive charging.
New keys for an 05 have been on ebay....but good luck getting them cut+coded to your car....but you could transplat the battry from an ebay key....
Old May 15, 2011 | 01:23 PM
Duvivr6's Avatar
Duvivr6
I ordered a Key for my R53 from e2orlando.com for $165 shipped give them a call awesome service!
Old May 15, 2011 | 02:27 PM
Capt_bj's Avatar
Capt_bj
the key's battery
and what keys you got: one with remote or two
changed over the years
also whether you could program a new key from the car or if it needs a dealer interaction
just in case you were wondering . . .
Old May 15, 2011 | 03:02 PM
rkw's Avatar
rkw
That doesn't necessarily mean that the battery is dead. See if you can reprogram the remote: https://www.northamericanmotoring.co...ogramming.html
JamesDeBart
Apr 16, 2016 05:00 PM
newminijcw
Oct 21, 2015 02:37 PM
BushOner
Sep 29, 2015 08:42 AM
jennster
Sep 28, 2015 06:19 PM
