Navigation & Audio XM receiver cChoice? Really confused.
Old Jan 22, 2004 | 03:19 PM
kraigster414's Avatar
kraigster414
Can you please tell me the pros and cons of the Delphi XM Roady, the Delphi XM Skifi and the XM Commander? And how about the quality of sound when played through your existing MINI FM radio? I have a 2004 Mini w/standard radio (not HK) on order. Also, which requires a dealer installation and which can I do myself keeping in mind I am severely tool challenged. Thanks.
Old Jan 22, 2004 | 09:27 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Old Jan 27, 2004 | 01:53 PM
sipde's Avatar
sipde
The XM Direct is pretty easy to install. You can find out more on it here:
http://www.radiosandmore.com/prod_de...R-D-001-BMW101
Old Jan 27, 2004 | 10:35 PM
fries's Avatar
fries
Blitzsafe is coming out with an adapter to connect a SkyFi to the CD changer harness (I believe). Benefits include seeing track info on your head unit, controlling the receiver with the MFSW, hidden application and having the portability of the SkyFi. Check out this thread:
http://www.xmfan.com/viewtopic.php?t...ht=mini+cooper
Unfortunately, it looks like it's a little delayed.
Old Jan 30, 2004 | 08:23 AM
Storer's Avatar
Storer
So, the ultimate question is... is the stock head unti satellite radio-ready? Can I just get a receiver and antenna and be good-to-go, or do I need to upgrade the head unit?
Old Jan 30, 2004 | 08:59 AM
Redleg13's Avatar
Redleg13
I've got both the Roady for my wife's car and the SkiFi for my Mini. Got the Roady first because it seemed easy: insert casette adapter into slot and run the antenna wire. My experience with the Roady left me less than satisfied: lots of wires hanging out, and the casette adapter made a rumbling noise. But I loved the music and wanted XM for my Mini, so I went with the SkiFi. Good move. Clean setup and sound. And I can pop the unit out and plug it into the XM boombox in the kitchen and listen in our home. Another plus of the SkiFi is that the lighting matches the Mini dash lighting. SkiFi is the clear winner.
Old Jan 30, 2004 | 09:07 AM
MINIDean's Avatar
MINIDean
2003 and later MINI's are satellite ready, however you must use the MINI Sirius system or the new XM-Direct unit to get full function satellite rado on the current MINI head unit.
I had the MINI system, but removed it for the XM Direct unit. I love it!
spec35
39
Jun 19, 2017 05:54 PM
Sep 29, 2015 03:36 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
