Interior/Exterior Pros and cons of Plasti-dip?
Old May 9, 2011 | 05:23 PM
drftobin's Avatar
drftobin
Thinking of blacking out the chrome on my mini with Plasti-Dip? Any info good or bad on the subject would be a great help from the mini masses???
Old May 9, 2011 | 06:35 PM
dannyhavok's Avatar
dannyhavok
Are you thinking of interior or exterior?
I did both shortly after I got my car, so about 8 months ago or so. It started to fade and get a little worn on the outside, and was looking sort of flat and cheap. That said I could have taken my time and done more coats, etc.
Interior looked decent and held out fine except where I put it on too thin or had some unevenness. For me I found it showed dust really badly. I removed it all today.
The Pros are that it's cheap, easy, reversible, and looks okay if you do a good job.
The Cons are that it is matte, subject to weathering, and can start to look sort of mickey mouse after awhile. I'd say it's a fun temporary mod and a good way to see if you like the blackout appearance enough to invest in vinyl.
Old May 10, 2011 | 05:17 PM
MINI33342's Avatar
MINI33342
I have had my beltline blacked out for over a year with no real issues. Looks good compared to the stock wheel arches.
Just make sure you do at least a couple of good coats. And you do need to score the tape edge with a razor as you will pull the Plasti-dip off when you try to remove the tape.
Old May 11, 2011 | 04:08 AM
N2MINI's Avatar
N2MINI
I've seen people use electrical tape for the belt line.
or 6-7 pieces of 48'' matte or gloss black vinyl from a local sign shop.
For me it's much easier to put it on and be done then to tape out half the car ( overspray ) to paint it..
Granted a can of spray is only 8 bucks..
I could cut the vinyl for the same though..
I used the plasti-dip for my Joey modded lights, but did the rings, handles, heck everything that is black on my car is vinyl of some sort....
patsum
26
May 29, 2021 06:29 PM
Doc Pain
Mar 10, 2021 04:50 AM
OutMotoring
Mar 3, 2017 06:29 AM
The Rossness
Sep 17, 2015 03:06 PM
tag1260
Tires, Wheels, & Brakes
Sep 10, 2015 08:57 AM
