hard start, time for a tune up?
Old May 6, 2011 | 12:06 PM
Cole9953's Avatar
Cole9953
been starting hard on me lately, 2-3 seconds of cranking before it really starts, but runs perfect after. at 58K miles now. am i just looking at a tune up (plugs and wires), or do you think it could be something else?
Old May 6, 2011 | 01:06 PM
HRM's Avatar
HRM
It may be something else, but really, it is always OK to replace the plugs at 50K miles, so you always end up starting there.
Old May 10, 2011 | 12:14 PM
Cole9953's Avatar
Cole9953
gonna check the plugs when i get of work, ordered WMW's ignition package any way. if plugs don't solve it, what should i do next?
Old May 10, 2011 | 05:08 PM
MINI33342's Avatar
MINI33342
What kind of gas are you using? Some lower grades have been known to cause startup problems as they don't have the additives to keep the injectors clean.
Old May 10, 2011 | 08:47 PM
Cole9953's Avatar
Cole9953
Kroger gas... might throw some seafoam in the tank tomorrow.
Old May 11, 2011 | 05:11 PM
MINI33342's Avatar
MINI33342
Kroger........
Try using a better grade of gas in addition to the seafoam.
Old May 31, 2011 | 08:14 AM
Cole9953's Avatar
Cole9953
so after new plugs, wires, coil pack, a can of sea foam, and 2 tanks of shell premium, I'm still getting a hard start about once a day. what should i check next?
Old May 31, 2011 | 10:09 AM
Jim Michaels's Avatar
Jim Michaels
If the hard starting seems to be related to the battery turning over the engine more slowly, you might check the battery. If the battery is spinning the engine over at normal speed, it's probably not the battery.
Old May 31, 2011 | 01:19 PM
HRM's Avatar
HRM
The was a thread recently about the fuel pressure regulator. It is on the rail and doesn't look expensive or hard to replace. The symptoms were the same and it turned out a bad regulator was not holding the pressure while sitting causing the pressure to take longer to come back to the right zone. The replaced everything in that thread and IIRC it went on for months. I would try that next for better or worse. I got a look at mine an it was butt ugly rusty so it is on my mind for the future.
Old May 31, 2011 | 01:22 PM
Cole9953's Avatar
Cole9953
any way to test the regulator other than to replace it?
Old May 31, 2011 | 01:35 PM
Cole9953's Avatar
Cole9953
also, part number on the regulator?
eliseo1981
Jan 28, 2021 02:45 PM
veevsato
Aug 5, 2015 04:42 AM
