will not idle after warmed up. stalls
Old May 2, 2011 | 03:15 PM
trdillon's Avatar
trdillon
this happened after a super charger replacement. I can start it when it is cold and it seams to run fine.... after driving for 10min or so it will not idle? wondering if i may have missed something during re assy.. any thought ?
Thanx
Rob
Old May 2, 2011 | 03:26 PM
HRM's Avatar
HRM
I am guessing a connector may be forgotten or not totally connected. Cold start is a preprogrammed formula, then once it is warm the computer takes over lots of things. If it is getting bad or no info, that may cause issues that are temp sensitive.
Just a guess, but double checking all vac lines and wires is a good place to start.
Old May 2, 2011 | 05:58 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Check the two lines which are behind and go into the lower intake duct. The black plastic one below - Part no. 16.
One of those if for Manifold Air pressure.
Old May 2, 2011 | 07:00 PM
trdillon's Avatar
trdillon
Ok , I will check all the above. Thank you , BTW it has not triped a Check engine light.... I also heard a Dirty Throttle body... Is there any sort of reset for the computer?
Old May 4, 2011 | 10:32 AM
trdillon's Avatar
trdillon
Fixed ! ! !
Ok, after reciving obd Codes 1107 0107 etc .... all manafold pressure issue . I thought about what started this in the first place. I missed 3 bolts , But i only found them after the Car had been driven 10 miles or so ....
installed the 3 missing bolts and thought that i had fixed the problem. but Now the car would not idle. This car does not have a mech Idle Air control. So it must do it with the computer.
I removed the Battery last night and let it sit. This will clear the computer. today with out making any other changes, I hooked up the battery and now the Computer has re taught it self and the Car runs PERFECT. I am now very happy, and Superchagertech.com came threw with the supercharger
Thank you David ( Warwick Mini ) for getting all of the parts to make this happen !!
Rob
Old May 9, 2011 | 04:45 AM
-=gRaY rAvEn=-
Moderator
LOL yeah extra bolts laying around after that type of work would be a concern though .
Which ones were they ?
I will have to look up those codes.
There is a way to reset the DME using your key and odometer reset but battery works too. There should be a thead in the "stock problems and issues" section.
navybsn
Oct 4, 2015 03:27 PM
micromini234
Sep 30, 2015 07:36 PM
Miniwaukee
Sep 29, 2015 09:22 AM
Huskyfan
GP Talk
Sep 28, 2015 06:08 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
