R50/53 need a little help
Old Jan 3, 2011 | 09:02 PM
liquid wrench's Avatar
liquid wrench
need a little help
I have an 04 MCS 6 speed and Im loving it it's dark silver .
I was trying to turn off the auto door locks and while I was deep into the computer via the trip reset I hit the wrong switch and somehow put it in some sort of "track mode"? the air bag light is lit the traction control light and the air pressure light. and I can;t get them to go off. it drives as if the traction control is turned off. I tried unhooking the battery to no avail.I checked fuses as far as I could.
Everything was working fine till I did what I did.
The dealer said it needed 2 grand worth of work to fix it :|
I have 30 + years machincal history including diognostics ,I know a little.
If there is anyone out there that knows what I have done and can help me fix it I would appreciate it very much.
I have a 1:00 appointment weds back at the dealership I hope I can get it fixed before then I don;t like driving her like it is. I bought a scan tool and as I suspected there were no codes. any help would be great!!
Old Jan 4, 2011 | 07:47 AM
liquid wrench
still in track mode
save me from the jaws of the dealer
less than 24 hours before I have to head there. a 2 hour ride is the worst part.
Old Jan 4, 2011 | 07:55 AM
liquid wrench
updated
one other thing I keep forgetting to mention at the time I did what I did the outside air temp temp reading was -37* thats has corrected itself.
Old Jan 7, 2011 | 09:44 PM
liquid wrench
updated track mode
I can not own the only Mini that someone has done this to.?
the dealer doesn't know whats wrong with it and they want to start throwing parts at it. I NEED A real MINI Person to help firgure this out.
Old Jan 8, 2011 | 07:06 AM
Floor-is's Avatar
Floor-is
Your dealer is a buffoon
There is a track mode setting, you can switch it on *and* off, plain and simple. I'll have to look in my books, it's in there somewhere. Hope to get back to you soon, but I should mention I won't get to look in my books for about a week..
Old Jan 8, 2011 | 09:07 AM
liquid wrench
track mode
any help would be appreciated...this just seems crazy to me. I can believe this....and the lack of knowledge on the dealers part.
Old Jan 8, 2011 | 09:58 AM
liquid wrench
I should also mention that when I get into the Lese 19 mode the display flashes ON/OFF ON/OFF but have yet to figure how to stop it from flashing.
Old Jan 8, 2011 | 10:11 AM
HRM's Avatar
HRM
I thought I posted my guess a few days ago, but I didn't...
How about disconnecting the battery for a while and see if it defaults back to a better state?
Old Jan 8, 2011 | 11:19 AM
Crashton's Avatar
Crashton
Turn off the track mode circuit & see if things revert back to normal. Also as HRM suggests pull the battery lead.
Here are the circuit instructions....
http://www.gbmini.net/wp/auto-up_windows/installation/
Old Jan 8, 2011 | 02:09 PM
liquid wrench
I did try the battery and many other things . I have the details in another post but not sure if I can move them to here?
Old Jan 10, 2011 | 03:43 PM
liquid wrench
I tried the holding the switches but it didn't have any effect thanks anyway.
Old Jan 14, 2011 | 05:34 AM
liquid wrench
still need help with this Mini
Ready to pull my hair out over this. There must be a repair shop working on Mini's in south western NY >?
Old Jan 15, 2011 | 11:49 AM
Floor-is's Avatar
Floor-is
After some digging around. Do you happen to remember if you where past #19 while hitting buttons?
If you've reset at #21, you're really screwed. If I am not mistaken, this resets the computer to factory-settings, the settings before they put it in the car and tell it it actually is sitting in a Mini.
Old Jan 17, 2011 | 08:14 PM
liquid wrench
codes from dealer read out
Im sorry it took me so long to get back here but I have been busy as well as you. I did go back to the dealer and after running what ever tests here are the codes they came up with. code 5D8C ABS-DSC:DSC sensor CAN time out
code 0090 GM :info-memory entrypen circuit,power supply BC1
code 5E19 ABS-DSC:CAN data default from DME/DDE(DSC lamp on as long as error is p......?
code 0015 MRS:Airbag,driver ,stage 2
Code 0085 MRS:Sensor for side airbag ,right
Im not sure where I was when i did what I did but I do know that 19 is as deep as I can go now and I can;t seem to find the ASA reset anymore?
I asked them to reset the lights and they were not able to do it even though they said that they were able to before.
So what if I did wat I did in Mode 19?
Did you read that now in 19 I get an on / off reading and can;t get an affect out of it to turn it on or off. ?
Old Jan 20, 2011 | 06:07 AM
Floor-is's Avatar
Floor-is
I'll look in my books in a few hours, will get back to you again
Old Jan 21, 2011 | 06:10 PM
liquid wrench
any luck ?
any luck Floris?
Old Jan 23, 2011 | 03:46 PM
liquid wrench
dealer help line.
Does Mini have a customer service line?
Somebody must know how to fix my problem?
Old Feb 3, 2011 | 04:22 PM
liquid wrench
anybody???
gonna drag it to fl. maybe there is some one there that knows minis.
Old Mar 29, 2011 | 06:39 PM
liquid wrench
back from fl.
So I didn't have any luck getting her fixed in fl. I guess she will run the rest of her life in track mode. It;s kind of sad that with all the mini lovers in the world no one knows how to correct this issue.
And it is also sad that Mini does not have a cust. service line that one could call to ask questions. I refuse to let them through parts at it. I created the problem so it must be able to be undone.
If there is a tech out there that has read this post for the first time and has any idea on this I'm more than willing to listen. Thanks !!
Old Mar 29, 2011 | 08:23 PM
Densmini's Avatar
Densmini
Have you tried getting an OBD-to-USB cable and EDIABAS/INPA software? Lots for sale cheap on fleabay, and it lets you deep into pretty much every system on the car- reset airbag lights, immobilizer synch, etc. It's what he dealer is using!
Old Mar 29, 2011 | 09:15 PM
firehawk618's Avatar
firehawk618
Sounds like you need someone with SSS Progman and DIS.
First thing i'd do is pull the current / past codes, save them and clear them.
2nd thing i'd do is try to re-code the insturment cluster to the car.
Old Mar 29, 2011 | 09:43 PM
lil zipr's Avatar
lil zipr
I have only owned my 06 MCS for a month so I may not much. but I did see on the OUTMOTORING website that they have a small pcb that you install to turn the track mode to default on when you start the car, instead of on. And then you can toggle the switch on or off, if you want. So maybe it would work in your situation. It was under the electrical section, maybe you can call or email them first, I believe it's only $50.
