will these fit an 07 S?
Old Dec 17, 2010 | 10:04 AM
Vic Mackey's Avatar
Vic Mackey
I stumbled across these on craigslist. I realize its hard to tell from a pic.....but bases on the photo and the info given will these fit an 07 "S" without any spacers, adaptors, ect? I know the seller says they will fit.....but I dont want any surprises.
http://detroit.craigslist.org/mcb/pts/2117555346.html
Thanks in advace.
Old Dec 17, 2010 | 10:17 AM
rjtrout2000's Avatar
rjtrout2000
Wouldn't see why not. Appears to be a Honda Civic style wheel (higher offset) You would have to see about the 14mm lug fitting it however, but a wheel like that should be fine
Old Dec 17, 2010 | 10:28 AM
John_B's Avatar
John_B
Check the backspacing. The diameter is fine, but if the backspacing puts them too far in or out you could have problems...
Old Dec 17, 2010 | 01:34 PM
mini coop's Avatar
mini coop
These are sold at Tire Rack. Call them and ask. The tire size is close to stock. At 65 mph you will be doing 63 mph with these. Given that the speedometer is off 5% you'll be going much slower than the speedometer reads with these tires.
Old Dec 18, 2010 | 06:28 AM
Mr Silverblood's Avatar
Mr Silverblood
Worse comes to worse, you could always meet the seller in a public location, like a mall parking lot, and ask if you could put one of the wheels on your Mini while you're both there to see if there are any issues.
For a set of Enkei's, $450 is pretty good.
Old Dec 19, 2010 | 01:55 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Thanks in advace.
Surprise, the tire size mounted is 205/40-17 which is 23.5" tire diameter or about 1" smaller than stock for the MINI. This would increase wheel gap for stock suspension and lower ride height for less road clearance when parking or driving. More risk for scraping.
Were you going to resell the tires and buy others?
You'll need centering rings to fit the wheels and MINI hub bore which is the same as the Civic, just ask for the rings with the wheels if you purchase.
Should fit. Likely offset is et+45 or 38mm of which 45 would be better for the MINI.
similar-
http://www.vividracing.com/catalog/e...0-p-60800.html
Old Dec 19, 2010 | 02:42 PM
Porthos's Avatar
Porthos
40 series tires are pretty ruff riding so be prepared.
trw92a
Aug 26, 2015 01:47 PM
Aug 25, 2015 07:11 AM
Aug 19, 2015 12:51 PM
Aug 12, 2015 01:24 PM
