Suspension Sway Bar Bushings and Cold
Old Nov 14, 2010 | 11:50 AM
iporkgoats's Avatar
iporkgoats
So last week the Temp. dropped significantly and i'm hearing a rattling from the rear of my car. i have the 25mm Hotchkis sway bar and i was greased a few months ago. Could the cold cause the sway bar and bushings to contract enough that there is a gap causing it to bang around?
Old Nov 15, 2010 | 04:47 AM
BostonR56S's Avatar
BostonR56S
I hear the same thing. Its really only on the first like 4 bumps i hit coming out of my bumpy road. Then it goes away. I have a 19mm bar, but same thing.
I'm using the WMW zerk bushings
Old Nov 15, 2010 | 11:57 AM
BostonR56S's Avatar
BostonR56S
Check your endlinks, the end connecting the link to the sway bar. That has to be pretty tight, otherwise they can bang against each other and create noise
W0TM8
Dec 19, 2019 07:50 AM
Mini7
Feb 2, 2016 07:52 PM
minimofo
Sep 9, 2015 10:29 AM
Hippiehobbit267
Sep 1, 2015 06:13 PM
minipopkart
Aug 13, 2015 05:22 AM
