Competition Clutch & Flywheel Kits now available at Helix!
Old Oct 15, 2010 | 07:16 AM
Ralph@Helix's Avatar
Ralph@Helix
We now offer Competition Clutch & Flywheel Kits for the Mini Cooper S 2002-2006
Competition Clutch Stage 2 Clutch/Flywheel Kit - utilizes an organic disc and is rated up to 300whp. If you still have a street driven MINI and find your stock clutch not holding your power then this is the kit for you.
The flywheel is single-mass, weighs 13.8lbs and is made of 4140 Forged Steel. There is no need to worry about ring gear separation or resurface packs to install like an aluminum flywheel.
The Pressure plate in this kit is rated at 1650lbs and is still able to provide a "soft-like" OE pedal feel.
The organic disc is a brass plus steelback disc which has a higher heat tolerance.
Kit includes: flywheel, clutch disc, pressure plate, upgraded heavy duty throw out bearing, hardware and alignment tool.
Overall Clutch & Flywheel assembly weight 25lbs
*We recommend replacing the guide tube as well.
*A stage 4 Clutch/Flywheel Kit is also available for racing applications and is rated up to 400whp. It utilizes a 6 puck ceramic disc.
http://www.helix13.com/mini/products/suspension-chasis
andrewjg1994
Jan 29, 2021 07:45 PM
madmax88
Aug 21, 2017 07:07 PM
Sep 17, 2015 09:27 AM
Zettinger
Aug 25, 2015 04:04 PM
Aug 25, 2015 12:58 PM
