Brake Pad Life - front versus rear?
Old Sep 26, 2010 | 09:10 AM
shark715's Avatar
shark715
I'm very surprised that the rear pads on our '03 MCS don't last far longer than the fronts. On every other front wheel drive car I've had, my experience has been that the rear brakes last far longer (2 to 3 times as many miles) as the fronts. But then again all the other front wheel drive cars I've had were drum brakes in the rear. Is that the difference? We have had our Mini since new, and much of our driving is on the highway, so brakes last a long time for us...each set of front pads have lasted 50,000-60,000 miles. But our experience has been that the rear pads last only 5,000-10,000 miles longer. Is that back to front ratio fairly typical? What has everyone else experienced? Thanks.
Old Sep 26, 2010 | 10:03 AM
slinger688's Avatar
slinger688
Usually 2 fronts 1 rear.
Old Sep 26, 2010 | 10:29 AM
ZippyNH's Avatar
ZippyNH
Yeah...but it depends on how you drive....I actually wore out my rears before the fronts!!
I guess I need to stomp on my brakes harder!!
With the corner braking system on the mini where any of the 4 brakes can be activated by the stability, traction control, and ABS, the old rules have kinda gone out the window!! Just replace them when they are worn out and thin!!
Old Sep 26, 2010 | 10:51 AM
jcauseyfd's Avatar
jcauseyfd
Just replaced my pads at 65k and wear was pretty even all the way around. Maybe a tad more left on the rears compared to the fronts, but not enough to be meaningful.
W0TM8
Dec 19, 2019 07:50 AM
bjcarter2
Aug 31, 2015 04:03 PM
StealthR53
Aug 8, 2015 10:59 AM
