Driver side Turn signal Issue - With Pics
Old Sep 22, 2010 | 03:36 PM
Fen52's Avatar
Fen52
Hello.
Auto Newbie here. I own a '05 MCS. Just yesterday when I signaled to make a left hand turn the interior indicator light was flickering faster than usual. Turns out the driver side turn signal isn't functioning and the driver side & rear indicator lights all flicker faster.
Here are the pics of what I discovered when I open the hood.
Is this the source of the problem? If so is this something I can fix (with no expertise but with reasonable intelligence)?
Or do I have to go to a shop?
Thanks in advance...
Attached Thumbnails Driver side Turn signal Issue - With Pics-photo-1.jpg   Driver side Turn signal Issue - With Pics-photo-2.jpg   Driver side Turn signal Issue - With Pics-photo-3.jpg
Old Sep 22, 2010 | 03:50 PM
JAB 67's Avatar
JAB 67
Either your car was in an accident and poorly repaired, or a rodent has been feasting on your wiring harness. Shouldn't be too hard to fix, with in-line splices and electrical tape.
Old Sep 22, 2010 | 04:05 PM
ScottRiqui's Avatar
ScottRiqui
Yep - looks like you've found the problem.
Usually, a faster-than-normal flash rate is a warning that one of your bulbs has burned out. In this case, the chewed-through wiring harness had the same effect (an open circuit in the turn signal circuit.)
Dec 23, 2015 10:36 AM
maestro39
Oct 27, 2015 02:38 PM
one73ronin
Aug 19, 2015 12:36 PM
messyjesse96
Aug 12, 2015 05:51 AM
nismo4life
Aug 5, 2015 08:31 AM
