Drivetrain Average Stock Clutch / Flywheel Lifespan?
Old Sep 5, 2010 | 03:48 AM
chorline's Avatar
chorline
Hey All. My non-LSD'd R53 is really getting on my nerves at the AutoX track. That being said I am looking to purchase a OSG LSD but I also understand that the installation of a LSD is basically the same for replacing the clutch and flywheel. My question is.. what is the average lifespan of a stock clutch / flywheel on a R53? My car is a 2005 with 44K miles and is primarily driven at the AutoX track (about a 2mile loop) 2-4 days out of the month (the rest is a few days of casual highway driving). I haven't noticed any gear slipping, additional noises, etc but don't want to get this LSD installed and 2 months later notice that the clutch needs to be replaced. At the last tune the car was doing about 210whp so I'm curious what the average lifespan of the clutch would be? If I'm right on the limits I may just bite the bullet and do it but if I can wait to do the clutch and flywheel until the spring and just get the LSD done now to fully enjoy the rest of the AutoX and Track season in New England that would be a bonus. Thanks in advance!
Old Sep 5, 2010 | 02:40 PM
msjulie33's Avatar
msjulie33
tranny out==big chunk of labor to replace clutch, like most of it so it's the parts that remain to decide but why pull the tranny twice...
decent shop should be able to comment on the condition of the friction disc and throw out bearing etc but if you like to slide that clutch hard on start, or pop it - consider tougher bits. my $.01
that power diff (from stock) isn't the issue on your clutch life, but how you use the clutch to get the power to the ground
Old Sep 5, 2010 | 07:37 PM
Some Guy's Avatar
Some Guy
33k miles, 3 seasons of AutoX, glazed pressure plate and flywheel, but plenty of friction material left. I measured the clutch thickness as .29in, compared with .33in someone quoted for a newish one. The clutch is considered full warn when it is basically right on the rivets, I was way off that.
I put in a torsen diff but left the stock clutch. Even the throwout bearing was like new, smooth as butter.
Old Sep 6, 2010 | 02:35 AM
chorline's Avatar
chorline
thanks guys. I'll have the shop take a look when they put in the diff in but it sounds like I may be able to hold off for another 6-12 months. Thanks again for your time.
Old Sep 7, 2010 | 04:16 PM
2Miniacs's Avatar
2Miniacs
Given the amount of effort to get the tranny off (speaking from personal experience) I would recommend replacing the clutch/pressure plate/flywheel/throwout bearing while the tranny is already out. If the stock set still has some life left then you could always keep it for down the road when/if the replacement set wears out.....
Old Sep 7, 2010 | 07:46 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
If they have the trans out go ahead and replace it. The cost to pull the trans again is so much that it doesn't make sense to wait.
Old Sep 7, 2010 | 08:11 PM
CrazyIvan's Avatar
CrazyIvan
Listen to this guy. No need to pay for 10-12 hours of labor again in six months to a year. Also for an extra 10 bucks replace the nylon bushings that release fork rod slide on.
andrewjg1994
Jan 29, 2021 07:45 PM
madmax88
Aug 21, 2017 07:07 PM
Sep 17, 2015 09:27 AM
Zettinger
Aug 25, 2015 04:04 PM
Aug 25, 2015 12:58 PM
