thermostat housing/computer removal - reprogram?
Old Aug 30, 2010 | 07:00 PM
erickvonzipper's Avatar
erickvonzipper
My '05 Cooper has a coolant escapage problem (again). It appears to be coming from the area of the thermostat housing (again).
Heres the (potential) problem: in order to confirm and/or repair, a number of things have to be removed, including what looks to be a computer or module. If I disconnect-to-remove this computer (or module), will any reprogramming have to be done when its reinstalled, or is it kind of just plug (back in) and play? The answer to this question will determine where it goes to have the leak repaired.
Old Aug 30, 2010 | 07:37 PM
ScottRiqui's Avatar
ScottRiqui
If you're talking about the ECU under the hood (oriented vertically, about the size of a paperback book with two harnesses coming out of it), then it can be removed and replaced without having to reset or reprogram anything.
Old Aug 31, 2010 | 04:40 AM
erickvonzipper
Thanks, Scott. Thats what I needed to know.
matthewbrakeii
May 13, 2021 08:39 AM
durablack
R55 :: Clubman Talk (2008+)
Oct 5, 2015 01:51 PM
greekzilla
Aug 23, 2015 03:44 PM
PSIChocolate
Aug 13, 2015 12:46 PM
kwijmbo
Aug 5, 2015 09:00 PM
