Popping Out of Gear
Old Aug 22, 2010 | 07:52 PM
5minutes's Avatar
5minutes
Popping Out of Gear
I have a 02' Cooper 111,000 mi. with the manual Midlands 5spd. Just the other day under normal driving I put it into 2nd and it jumped out of gear. I then tried again and made sure it was fully engaged. It jumped again, I have to semi-forcefully hold it to use 2nd gear. Is there some type of gear lock or retaining clip, maybe the pressure plates of the clutch are going bad? It only does it in 2nd gear. Ive read horror stories about the Midlands but everything seems fine except for 2nd. Any ideas of tips would be great.
Old Aug 23, 2010 | 07:03 AM
thulchatt's Avatar
thulchatt
Sorry, but I think this is the start of something bad.
I had a transmission on a honda which started going bad by jumping out of gear. I don't know a bunch about transmissions so I am not any help but with the honda it was the syncros going out. It just kept getting worse until I had a used replacement put in. It may be something different but you should probably get to a shop to have it checked ASAP.
Old Aug 23, 2010 | 07:10 AM
Helix13mini's Avatar
Helix13mini
Yup.
Old Aug 23, 2010 | 09:44 AM
5minutes's Avatar
5minutes
Alright thanks, im taking it to the dealer today, despite them not wanting to answer a single question I had. And I did some research and it does sound like a syncro gear. There made of brass and not steel like the rest of the gears and they wear out. Thanks for the help.
Old Aug 23, 2010 | 09:51 AM
cristo's Avatar
cristo
Alliance Member
Does sound like a worn out 2nd gear synchro ring.
Click and Clack (the Car Talk guys) would suggest something involving a bungee cord to keep it in gear while driving.
Old Aug 23, 2010 | 09:59 PM
Calz's Avatar
Calz
Either a bad syncro or shifter detent... both of which are inside the transmission
Old Aug 24, 2010 | 03:34 PM
5minutes's Avatar
5minutes
thats what the MINI Tech said at the dealer after a quick drive. The dealer quoted me $2,700 for a rebuilt gearbox plus $800 for labor. Or just the synchros, a few guide sleves, and a new second shift gear. Those suggested parts cost about $1,000 with $1,600 for labor. So I'm going to take it to a transmission shop I called that has worked on Minis. Regardless the route i take, no Mini for a while.
rob&JCW
Feb 21, 2018 02:41 PM
embiggenedmini
Oct 15, 2015 12:36 PM
jarymo
Hawaii MINI Motoring Club
Sep 30, 2015 04:19 PM
Rainforest_Elf
Sep 15, 2015 12:11 PM
Sep 3, 2015 02:06 PM
