help?
Old Jul 29, 2010 | 12:22 AM
05miniR53's Avatar
05miniR53
help?
I already did the search thing and i can't find it. And im new to here so please dont rip me up....im just asking for help. Low boost, i smell fuel. usually runs 12 lbs its at 4. and i dont remember the exact code its throwing, but it reads too much boost under deceleration. Any ideas?
Old Jul 29, 2010 | 05:12 AM
Fatherdeth's Avatar
Fatherdeth
You're going to have to be a little more descriptive. My guess with what you are saying is maybe some bad fuel (that's my answer to everything), but in all seriousness.....How does the car run? Does it sputter and hesitate on take off. If it runs decent, does it have some get up and go? I know just recently the vacuum connector for my boost gauge was dry rotted and I only read 8 psi of boost at WOT where I was used to seeing 17. I replaced that and got my boost readings back and I checked all the other components ie. Throttlebody, intercooler bellows for leaks. Can you get the exact code for us?
Old Jul 29, 2010 | 10:28 AM
05miniR53's Avatar
05miniR53
I can't get thee exact code again till this weekend, but. Its terrible on takeoff, bogs, then goes. Even at a cruising speed you can watch it go from 0 to 6 vacuum up and down up and down. I was told It could be the bypass valve so I'm installing that on Saturday. But I smell fuel, that should have nothing to do with that. And as far as the boost gauge, I checked the lines, and you can tell there is a total power loss.
Old Jul 29, 2010 | 11:43 AM
05miniR53's Avatar
05miniR53
