Drivers side rear brake pads rattling/clanking noise
Old Jul 22, 2010 | 08:46 PM
saturn5rocket's Avatar
saturn5rocket
I have an 02 MC with Hawk HP Plus brake pads on stock rotors. They will often rattle/clank at speeds up to about 40 mph and the sound goes away when the brakes are applied. Warped rotors??? Do I need to replace the pads?? The brakes are working fine, but the noise is quite annoying.
Wes
Old Jul 22, 2010 | 09:16 PM
vizcarmb's Avatar
vizcarmb
I have the same exact issue. Mine is more like a clicking noise but stops when I hit the brakes. What I realized was that when I removed the wheel the brake pads are a little loose on the carrier. So I tried reappling brake disc quiet and it went away for 2 days. Then the noise came back. If you noticed there is a gap between the pads and carrier. I would suggest some type of shim and fill that gap between the carrier and the brake pad ears. Hope this helps.
Old Jul 23, 2010 | 04:58 AM
Capt_bj's Avatar
Capt_bj
on an 02 the inner rear pad should be held onto the piston with a spring clip; there's a groove around the piston lip
sometimes this doesn't get clipped on right and they can move around.
This is the back of a rear, inside GEN1 (I've used a few different brands over the years but all had similar setup)
W0TM8
Dec 19, 2019 07:50 AM
maestro39
Oct 27, 2015 02:38 PM
messyjesse96
Aug 12, 2015 05:51 AM
