Interior/Exterior i need bolt sizes for rear seats
Old Jul 4, 2010 | 06:55 PM
zachsa's Avatar
zachsa
2 months ago i removed my back seats for an auto cross event and just recently moved to a new place, lost the bolts to the rear seats in the move...
so does anyone have the bolt sizes for rear seats and how many?
Old Jul 8, 2010 | 02:01 AM
xnotfunkylex's Avatar
xnotfunkylex
There are no bolts that hold the rear seat in a 1st gen car. Only the one that goes into the center bit for the backs. But I don't think it is totally necessary to have.
Old Jul 8, 2010 | 02:02 AM
xnotfunkylex
See.
Old Jul 9, 2010 | 11:33 AM
zachsa's Avatar
zachsa
i remember removing bolts to remove rear seats..theres 3 bolts... all in the center...
these
Old Jul 9, 2010 | 03:17 PM
rkw's Avatar
rkw
I guess you simply unbolted the middle hinge for folding the seats, instead of removing seat backs separately (normal way to remove the rear seat and involves one bolt).
The parts catalog says the bolt is M8x30 and the car uses a total of 7 of them. You can purchase part# 52207056516 at the dealer. A good hardware store may also have M8x30.
http://www.realoem.com/bmw/showparts...69&hg=52&fg=30
Item # 8:
Old Jul 9, 2010 | 04:36 PM
zachsa's Avatar
zachsa
^ thank you..wish i would of had those removal directions..the ones i got off here told me to remove those bolts...
Old Jul 12, 2010 | 10:28 PM
xnotfunkylex
That's the first time I've seen those removed to take the seat out. Seems a little harder that way.
Glad someone here found the bolts that you need though.
Old Jul 12, 2010 | 10:54 PM
zachsa's Avatar
zachsa
i still dont understand the way you posted...can you give more detail on rear seat removal..your way..im curious..but yes glad to know what bolts i need.
Old Jul 12, 2010 | 11:19 PM
xnotfunkylex
If you put the back of the seats down you will bee able to see a bolt in the middle bottom of the seats. (only 1 bolt) Once you remove that, there is a latch that you can slide up (I think, maybe down, only goes one way though)( #4 in RKW's picture is the latch that I am talking about). After that is out of the way you can remove the inside corner of the seat from the bracket. After that, tilt the seat up as if you were putting back into its normal position. While doing that pull towards the opposite side of the car from the seat back you are holding, and at about 45 degrees the seat should pop out. (# 3 in RKW's picture is where the seat will pop out of at that magic angle)
Once both seats are out, the bracket that you removed will be left in place in the center of the car.
Let me know if you need any more help. I think I made that confusing enough though. But honestly, once you see that one bolt the process is very straight forward.
kazyn
Oct 25, 2019 02:34 PM
mishanja
Jun 22, 2016 09:59 AM
Mini'mon
Aug 26, 2015 01:02 PM
mini4thewini
Aug 19, 2015 05:18 PM
