How to Test Control Arm Bushing
Old Jul 4, 2010 | 10:50 AM
karlInSanDiego's Avatar
karlInSanDiego
Have an '07 R56 with 76k miles. Recently (abruptly) picked up a clunk on pass side front corner. Can't find anything loose, broken, or missing when I lift the front end to inspect.
Can someone please describe exactly how to test for failed control arm bushings (mine are originals)? Short of pulling them off, I'm not sure how look test if they're FUBAR.
If I can't confirm they're bad, I'm planning to order Bilstein HD struts and start that job. At the same time, I'll get a chance to loosen and torque a bunch of front end parts and hopefull the culpret will show it's ugly head. Should I just go ahead and order the bushings (and for $6 more the whole bushing assembly) for both sides and replace that which is known to not last this long on average anyway?
Old Jul 4, 2010 | 02:44 PM
slinger688's Avatar
slinger688
Look at the front sway bar Bolts. The other thing to look at is the bolt on the top plate. I had some clunking from these two areas before. Cleared up after some tightening.
Old Jul 4, 2010 | 06:41 PM
Benibiker's Avatar
Benibiker
Transmission and engine mounts can cause the same noise too.
Old Jul 4, 2010 | 08:54 PM
karlInSanDiego
Thanks guys!
W0TM8
Dec 19, 2019 07:50 AM
Mini7
Feb 2, 2016 07:52 PM
Toolman
Jan 20, 2016 06:50 AM
maestro39
Oct 27, 2015 02:38 PM
JPMontes3
Aug 23, 2015 01:26 AM
