Wheel Lift
Old Apr 28, 2010 | 06:10 AM
slinger688's Avatar
slinger688
Wheel Lift
My R56 MCS in a fairly aggressive turn, my rear trailing wheel lifts off the ground with about 3-4 inches of air space. I pretty much run a stock suspension with a 22MM rear sway bar set at the softest setting and a mild camber of -1.4 in the front. The rear unloaded wheel lift in the start of the turn then stop and on track out falls back onto the ground. This happens with straight braking/turn, trail braking and a light throttle breathe/turn under power with no brakes.
What does DSC do when the wheel lift under power? As far as I can tell, it does nothing.
Old Apr 28, 2010 | 03:23 PM
howsoonisnow1985's Avatar
howsoonisnow1985
Think DSC might know traction and weight is on the opposite side also wonder what ABS does under heavy trail brake.
Old Apr 28, 2010 | 04:24 PM
slinger688's Avatar
slinger688
Seems a little smarter than I thought. Maybe it is an override?
I never had ABS turn on under trail braking. And I am from the Skippy school philosophy. I drive people crasy because almost every turn can be a trail braking opportunity.
twistedimages
Sep 19, 2024 04:13 AM
mellocooper
R55 :: Clubman Talk (2008+)
Jul 21, 2016 05:05 PM
minimofo
Sep 9, 2015 10:29 AM
atenzany62
Aug 26, 2015 09:26 AM
kpl
Aug 11, 2015 04:52 AM
