R50/53 Oil Filter question
Old Apr 17, 2010 | 02:26 PM
gbtr6's Avatar
gbtr6
Oil Filter question
We have a 05 MCS Convert. Took it to Tires Plus, and am normally satisified with them, but they couldn't get the canister off the engine. They didn't want to torque too hard on it so as to crack it. They are going to get another one first. Anyone else have this issue? Do they break? How are these attached? A long bolt, or just the nut being integral to the canister, screwing into the block. Any info helpful.
Thanks,
Perry
Old Apr 17, 2010 | 04:15 PM
kazlot's Avatar
kazlot
Oil Filter question
This page: http://www.realoem.com/bmw/partgrp.d...19&hg=11&fg=30 should answer most of your questions.
Hope this helps...
Old Apr 17, 2010 | 04:23 PM
DixonL2's Avatar
DixonL2
And if you want the short answer, the "nut" is cast into th canister iteself and is difficult to break. The canister doesn't need a gorilla's torque on it since the o-ring does the sealing. Also, "break" the seal by unscrewing the housing, then LET IT SIT 5 MINUTES. This drains the oil from the canister, making for a mess-free change. You reminded me... I have to change my oil...
Old Apr 17, 2010 | 04:32 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I haven't broken one yet. It takes a 36mm socket to get it off. We find them way over tightened from quick lube places all the time. I alot of times have to put a cheater bar on the ratchet to get them loose. Do that to get it off and replace it, then tighten it to 25 NM torque.
Old Apr 17, 2010 | 04:46 PM
gbtr6's Avatar
gbtr6
Thanks for the quick responses. Good to know they are hard to break. I'll also pass on the torque spec, so they don't overtighten.
Thanks,
Perry
Kimolaoha
Jul 5, 2023 01:04 PM
devicemanager
Jun 17, 2016 06:18 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
Lex2008
Aug 16, 2015 08:33 PM
Laura Redd Casler
Aug 15, 2015 09:32 PM
